S1DRX
S1DRX
    NEXPERIA(安世)
    SOD-123W(CFP3)
    RECTIFIER PN 200V 1A SOD123W
S1DRX 数据手册
S1DR 200 V, 1 A high power density, standard switching time PNrectifier 10 January 2018 Product data sheet 1. General description High power density, standard switching time PN-rectifier with high-efficiency planar technology, encapsulated in a small and flat lead SOD123W Surface-Mounted Device (SMD) plastic package. 2. Features and benefits • • • • • • • • • • • Forward current IF ≤ 1 A Reverse voltage VR ≤ 200 V Standard switching time Low forward voltage Low reverse current Low inductance Small and flat lead SMD plastic package Package high typ. 1 mm High power capability due to clip-bond technology Planar die design Capable for reflow and wave soldering 3. Applications • • • General-purpose rectification Reverse polarity protection Standard switching applications 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit IF(AV) average forward current δ = 0.5 ; f = 20 kHz; square wave; Tsp ≤ 140 °C - - 1 A VRRM repetitive peak reverse Tj = 25 °C voltage - - 200 V VR reverse voltage - - 200 V VF forward voltage IR [1] reverse current IF = 1 A; pulsed; Tj = 25 °C [1] - 880 960 mV IF = 1 A; pulsed; Tj = 125 °C [1] - 750 830 mV VR = 200 V; pulsed; Tj = 25 °C [1] - 0.1 200 nA VR = 200 V; pulsed; Tj = 125 °C [1] - 0.03 20 µA Very short pulse, in order to maintain a stable junction temperature. S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K cathode 2 A anode Simplified outline 1 Graphic symbol 2 CFP3 (SOD123W) 2 1 006aab040 6. Ordering information Table 3. Ordering information Type number S1DR Package Name Description Version CFP3 plastic, surface mounted package; 2 terminals; 2.6 mm x 1.7 mm SOD123W x 1 mm body 7. Marking Table 4. Marking codes Type number Marking code S1DR KS S1DR Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 2 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VRRM repetitive peak reverse voltage Tj = 25 °C - 200 V VR reverse voltage - 200 V VRMS RMS voltage - 140 V IF forward current δ = 1 ; Tsp ≤ 135 °C - 1.4 A IF(AV) average forward current δ = 0.5 ; f = 20 kHz; square wave; Tsp ≤ 140 °C - 1 A IFSM non-repetitive peak forward current tp = 8.3 ms; Tj(init) = 25 °C; single half sine wave (applied at rated load condition) - 25 A Ptot total power dissipation Tamb ≤ 25 °C [1] - 735 mW [2] - 1.19 W Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) [1] [2] [3] thermal resistance from junction to solder point Min Typ Max Unit [1] - - 170 K/W [2] - - 105 K/W [3] - - 15 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . Soldering point of cathode tab. S1DR Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 3 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier aaa-027902 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.50 0.33 0.25 0.20 0.10 10 0.05 0.01 0.02 0 1 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 1. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-027903 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.50 0.33 0.25 0.20 10 0.10 0.05 0.01 0.02 0 1 10-3 10-2 10-1 FR4 PCB, mounting pad for cathode 1 cm Fig. 2. 1 10 102 tp (s) 2 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values S1DR Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 4 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions V(BR)R reverse breakdown voltage IR = 100 µA; pulsed; Tj = 25 °C VF forward voltage IR reverse current Min Typ Max Unit [1] 200 - - V IF = 1 A; pulsed; Tj = 25 °C [1] - 880 960 mV IF = 1 A; pulsed; Tj = 125 °C [1] - 750 830 mV VR = 200 V; pulsed; Tj = 25 °C [1] - 0.1 200 nA VR = 200 V; pulsed; Tj = 125 °C [1] - 0.03 20 µA - 12 - pF - - 1.8 µs Cd diode capacitance trr reverse recovery time ; IF = 0.5 A; IR = 1 A; IR(meas) = 0.25 A; step recovery Tj = 25 °C [1] VR = 4 V; f = 1 MHz; Tj = 25 °C Very short pulse, in order to maintain a stable junction temperature. aaa-027904 10 IF (A) aaa-027905 10-7 IR (A) 1 10-8 10-1 10-9 (1) (2) (3) 10-2 10-10 (1) (2) (3) 10-3 10-4 0 0.4 (4) (4) (5) 0.8 10-11 VF (V) 1.2 pulsed condition (1) Tj = 150 °C (2) Tj = 125 °C (3) Tj = 85 °C (4) Tj = 25 °C (5) Tj = -40 °C Fig. 3. Product data sheet 0 40 80 120 160 VR (V) 200 pulsed condition (1) Tj = 150 °C (2) Tj = 125 °C (3) Tj = 85 °C (4) Tj = 25 °C Forward current as a function of forward voltage; typical values S1DR 10-12 Fig. 4. Reverse current as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 5 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier aaa-027906 30 aaa-027907 1.25 PF(AV) (W) Cd (pF) (4) 1.00 20 (3) 0.75 (2) 0.50 (1) 10 0.25 0 0 40 80 120 160 VR (V) 0 200 f = 1 MHz; Tamb = 25 °C Fig. 5. Fig. 6. aaa-027908 IF(AV) (A) 1.5 Average forward power dissipation as a function of average forward current; typical values aaa-027909 IF(AV) (A) (2) (1) (3) 0.010 1.0 1.5 (1) PR(AV) (mW) 0.5 Tj = 150 °C (1) δ = 0.1 (2) δ = 0.2 (3) δ = 0.5 (4) δ = 1; DC Diode capacitance as a function of reverse voltage; typical values 0.015 0 1.0 (2) (4) (3) 0.005 0.5 (4) 0 0 50 100 150 VR (V) 0 200 Tj = 150 °C (1) δ = 1; DC (2) δ = 0.9 (3) δ = 0.8 (4) δ = 0.5 Fig. 7. Average reverse power dissipation as a function of reverse voltage; typical values S1DR Product data sheet 0 25 50 75 100 125 150 175 Tamb (°C) FR4 PCB, standard footprint Tj = 150 °C (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz Fig. 8. Average forward current as a function of ambient temperature; typical values All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 6 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier aaa-027910 1.5 (1) IF(AV) (A) 1.0 aaa-027911 1.5 (1) IF(AV) (A) 1.0 (2) (2) (3) (3) 0.5 0.5 (4) 0 0 (4) 25 50 75 100 125 0 150 175 Tamb (°C) 2 FR4 PCB, mounting pad for cathode 1 cm Tj = 150 °C (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz Fig. 9. 0 25 50 75 100 125 150 175 Tsp (°C) Tj = 150 °C (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz Fig. 10. Average forward current as a function of solder point temperature; typical values Average forward current as a function of ambient temperature; typical values 11. Test information IF IR(meas) time IR trr 006aad022 Fig. 11. Reverse recovery definition S1DR Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 7 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier P t2 t1 t2 duty cycle δ = t1 t 006aaa812 Fig. 12. Duty cycle definition The current ratings for the typical waveforms are calculated according to the equations: IF(AV) = IM × δ with IM defined as peak current, IRMS = IF(AV) at DC, and IRMS = IM × √δ with IRMS defined as RMS current. 12. Package outline 1.9 1.5 1.1 0.9 1 0.6 0.3 3.7 3.3 2.8 2.4 2 1.05 0.75 0.22 0.10 Dimensions in mm 08-11-06 Fig. 13. Package outline CFP3 (SOD123W) 13. Soldering 4.4 2.9 2.8 solder lands 1.1 1.2 (2×) (2×) 2.1 1.6 solder resist solder paste occupied area 1.1 (2×) 1.2 (2×) Dimensions in mm sod123w_fr Fig. 14. Reflow soldering footprint for CFP3 (SOD123W) S1DR Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 8 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier Wave soldering footprint information SOD123W 8.3 4.8 1.8 3.5 2.4 (2×) 2.55 (2×) 3.0 (2×) 3.15 (2×) occupied area solder resist solder lands dummy track (solder resist and Cu free) Dimensions in mm Issue date 17-06-06 17-06-07 sod123w_fw Fig. 15. Wave soldering footprint for CFP3 (SOD123W) S1DR Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 9 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes S1DR v.1 20180110 Product data sheet - - S1DR Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 10 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer S1DR Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’ warranty of the product for such automotive applications, use and specifications, and (b) whenever All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 11 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier customer uses the product for automotive applications beyond Nexperia’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’ standard warranty and Nexperia’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. S1DR Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 12 / 13 S1DR Nexperia 200 V, 1 A high power density, standard switching time PN-rectifier 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 5 11. Test information......................................................... 7 12. Package outline.......................................................... 8 13. Soldering..................................................................... 8 14. Revision history........................................................10 15. Legal information..................................................... 11 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 January 2018 S1DR Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2018 © Nexperia B.V. 2018. All rights reserved 13 / 13
S1DRX 价格&库存
很抱歉,暂时无法提供与“S1DRX”相匹配的价格&库存,您可以联系我们找货
S1DRX
  • 3000+0.417533000+0.05390
  • 6000+0.373916000+0.04827
  • 9000+0.351659000+0.04540
  • 15000+0.3266215000+0.04217
  • 21000+0.3117821000+0.04025
  • 30000+0.2973630000+0.03839
  • 75000+0.2656775000+0.03430
  • 150000+0.24610150000+0.03177
  • 300000+0.22975300000+0.02966
