MBR3035PT – MBR30200PT
Taiwan Semiconductor
30A, 35V - 200V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
35 - 200
V
IFSM
200
A
TJ MAX
150
°C
Package
TO-247AD (TO-3P)
Configuration
Dual dies
Switching mode power supply (SMPS)
Adapters
Monitor
DC to DC converters
TV
MECHANICAL DATA
Case: TO-247AD (TO-3P)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 1.13 N⋅m maximum
Polarity: As marked
Weight: 6.10g (approximately)
TO-247AD (TO-3P)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse surge
(1)
current
Peak repetitive forward
current (Rated VR, Square
wave, 20KHz)
Notes:
1. tp = 2.0μs, 1.0KHz
MBR
SYMBOL 3035
PT
MBR
3035
PT
MBR
3045
PT
MBR
3045
PT
MBR
3050
PT
MBR
3050
PT
MBR
3060
PT
MBR
3060
PT
MBR MBR MBR MBR
3090 30100 30150 30200 UNIT
PT
PT
PT
PT
MBR MBR MBR MBR
PT
PT
PT
PT
VRRM
35
45
50
60
90
100
150
200
V
VR(RMS)
24
31
35
42
63
70
105
140
V
IF
30
A
IFSM
200
A
IRRM
2
1
IFRM
30
1
A
A
Version: K2103
MBR MBR MBR MBR MBR MBR MBR MBR
SYMBOL 3035 3045 3050 3060 3090 30100 30150 30200 UNIT
PT
PT
PT
PT
PT
PT
PT
PT
PARAMETER
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
dV/dt
10,000
V/μs
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1.4
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
MBR3035PT
MBR3045PT
MBR3050PT
MBR3060PT
MBR3090PT IF = 15A, TJ = 25°C
MBR30100PT
MBR30150PT
SYMBOL
TYP
MAX
UNIT
V
0.75
V
0.85
V
0.95
V
1.05
V
0.82
V
V
V
1.02
V
1.10
V
0.60
V
0.65
V
0.75
V
0.92
V
MBR30200PT
MBR3035PT
MBR3045PT
MBR3050PT
MBR3060PT
MBR3090PT IF = 30A, TJ = 125°C
MBR30100PT
MBR30150PT
V
0.73
V
V
V
0.98
V
MBR30200PT
V
MBR30200PT
MBR3035PT
MBR3045PT
MBR3050PT
MBR3060PT
MBR3090PT IF = 30A, TJ = 25°C
MBR30100PT
MBR30150PT
Forward voltage per diode
(1)
MBR30200PT
MBR3035PT
MBR3045PT
MBR3050PT
MBR3060PT
MBR3090PT IF = 15A, TJ = 125°C
MBR30100PT
MBR30150PT
VF
Notes:
1. Pulse test with PW = 0.3ms
2
Version: K2103
PARAMETER
Reverse current @ rated VR
(2)
per diode
CONDITIONS
MBR3035PT
MBR3045PT
MBR3050PT
MBR3060PT
MBR3090PT TJ = 25°C
MBR30100PT
MBR30150PT
MBR30200PT
MBR3035PT
MBR3045PT
MBR3050PT
MBR3060PT
TJ = 125°C
MBR3090PT
MBR30100PT
MBR30150PT
MBR30200PT
SYMBOL
IR
TYP
MAX
UNIT
1000
µA
500
µA
100
µA
mA
15
mA
10
mA
Notes:
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBR30xPT
TO-247AD (TO-3P)
30 / Tube
MBR30xPTH
TO-247AD (TO-3P)
30 / Tube
Notes:
1. “x” defines voltage from 35V(MBR3035PT) to 200V(MBR30200PT)
2. “H” means AEC-Q101 qualified
3
Version: K2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
3035PT - 3045PT
3050PT - 30600PT
3090PT - 30200PT
30
25
CAPACITANCE (pF)
10
1000
5
f=1.0MHz
Vsig=50mVp-p
100
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
10
1
TJ=25°C
3035PT - 3045PT
3050PT - 30200PT
0.001
10
40
50
60
70
80
90
100
100010
100 1
3035PT - 3045PT
3050PT - 3060PT
3090PT
- 30200PT
UF1DLW
TJ=125°C
TJ=125°C
10
0.1
TJ=25°C
1
0.01
TJ=25°C
0.1
0.001
0.00.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.2
0.4
0.4
0.5
0.60.6 0.7 0.8
0.8
1.0
0.9
11.2 1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
250
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
0.01
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
0.1
10
200
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
4
(A)
AVERAGE FORWARD CURRENT (A)
35
Version: K2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: K2103
PACKAGE OUTLINE DIMENSIONS
TO-247AD (TO-3P)
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: K2103
很抱歉,暂时无法提供与“MBR3060PT C0G”相匹配的价格&库存,您可以联系我们找货
