MBR1035CT - MBR10200CT
Taiwan Semiconductor
CREAT BY ART
10A, 35V - 200V Dual Common Cathode Schottky Rectifiers
FEATURES
- Low power loss, high efficiency
- Guard ring for over-voltage protection
- High surge current capability
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21
MECHANICAL DATA
Case: TO-220AB
TO-220AB
Molding compound, UL flammability classification rating 94V-0
Part No. with suffix "H" means AEC-Q101 qualified
Packing code with suffix "G" means green compound (halogen-free)
Terminal: Matte tin plated leads, solderable per JESD22-B102
Meet JESD 201 class 2 whisker test
Polarity: As marked
Mounting torque: 0.56 Nm max.
Weight: 1.88 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
MBR
MBR
MBR
MBR
MBR
MBR
MBR
MBR
1035
1045
1050
1060
1090 10100 10150 10200
CT
CT
CT
CT
CT
CT
CT
CT
UNIT
Maximum repetitive peak reverse voltage
VRRM
35
45
50
60
90
100
150
200
V
Maximum RMS voltage
VRMS
24
31
35
42
63
70
105
140
V
Maximum DC blocking voltage
VDC
35
45
50
60
90
100
150
200
V
Maximum average forward rectified current
IF(AV)
10
A
Peak repetitive forward current
(Rated VR, Square Wave, 20KHz)
IFRM
10
A
Peak forward surge current, 8.3 ms single half sine-wave
superimposed on rated load
IFSM
120
A
Peak repetitive reverse surge current (Note 1)
IRRM
Maximum instantaneous forward voltage (Note 2)
IF= 5 A, TJ=25°C
IF= 5 A, TJ=125°C
IF= 10 A, TJ=25°C
IF= 10 A, TJ=125°C
Maximum reverse current @ rated VR
TJ=25°C
TJ=125°C
VF
IR
1
0.5
A
0.70
0.80
0.85
0.88
0.57
0.65
0.75
0.78
0.80
0.90
0.95
0.98
0.67
0.75
0.85
0.88
2
5
0.1
15
10
V
mA
Voltage rate of change (Rated VR)
dV/dt
10000
V/μs
Typical thermal resistance
RθJC
1.5
°C/W
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
Operating junction temperature range
Storage temperature range
Note 1: tp = 2.0 μs, 1.0KHz
Note 2: Pulse test with PW=300μs, 1% duty cycle
Version: N1512
ORDERING INFORMATION
PART NO.
PART NO.
PACKING CODE
SUFFIX
MBR10xxCT
(Note 1)
H
PACKING CODE
SUFFIX
C0
PACKAGE
PACKING
TO-220AB
50 / Tube
G
Note 1: "xx" defines voltage from 35V (MBR1035CT) to 200V (MBR10200CT)
*: Optional available
EXAMPLE
EXAMPLE
PART NO.
MBR1060CTHC0G
PART NO.
PART NO.
SUFFIX
MBR1060CT
PACKING CODE
PACKING CODE
H
DESCRIPTION
SUFFIX
C0
AEC-Q101 qualified
Green compound
G
RATINGS AND CHARACTERISTICS CURVES
FIG. 2 MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
AVERAGE FORWARD A
CURRENT (A)
12
10
8
6
4
Resistive or
inductive load
with heat sink
2
100
150
PEAK FORWARD SURGE CURRENT (A)
FIG.1 FORWARD CURRENT DERATING CURVE
180
150
8.3ms single half sine wave
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
CASE TEMPERATURE (°C)
FIG. 4 TYPICAL REVERSE CHARACTERISTICS
FIG. 3 TYPICAL FORWARD CHARACTERISTICS
100
1000
INSTANTANEOUS REVERSE CURRENT (mA)
INSTANTANEOUS FORWARD CURRENT (A)
Pulse width=300μs
1% duty cycle
100
MBR1050CT-1060CT
10
MBR1035CT-1045CT
MBR1090CT-10100CT
1
MBR10150-10200CT
0.1
0.2
0.4
0.6
0.8
1
FORWARD VOLTAGE (V)
1.2
1.4
10
TJ=125°C
1
TJ=75°C
0.1
0.01
TJ=25°C
0.001
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Version: N1512
FIG. 5 TYPICAL JUNCTION CAPACITANCE
FIG. 6 TYPICAL TRANSIENT THERMAL
CHARACTERISTICS PER LEG
100
f=1.0MHz
Vsig=50mVp-p
TRANSIENT THERMAL
IMPEDANCE (°C/W)
JUNCTION CAPACITANCE (pF) A
10000
1000
10
1
0.1
100
0.1
1
10
0.01
100
0.1
1
10
100
T-PULSE DURATION. (s)
REVERSE VOLTAGE (V)
PACKAGE OUTLINE DIMENSIONS
TO-220AB
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
10.50
0.413
B
2.62
3.44
0.103
0.135
C
2.80
4.20
0.110
0.165
D
0.68
0.94
0.027
0.037
E
3.54
4.00
0.139
0.157
F
14.60
16.00
0.575
0.630
G
13.19
14.79
0.519
0.582
H
2.41
2.67
0.095
0.105
I
4.42
4.76
0.174
0.187
J
1.14
1.40
0.045
0.055
K
5.84
6.86
0.230
0.270
L
2.20
2.80
0.087
0.110
M
0.35
0.64
0.014
0.025
MARKING DIAGRAM
P/N
= Specific Device Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: N1512
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: N1512
很抱歉,暂时无法提供与“MBR10150CTC0”相匹配的价格&库存,您可以联系我们找货
