MUR105S – MUR160S
Taiwan Semiconductor
1A, 50V - 600V Ultra Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Ultra Fast recovery time for high efficiency
Low forward voltage, low power loss
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
50 - 600
V
IFSM
40, 35
A
TJ MAX
175
°C
APPLICATIONS
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
MUR
SYMBOL
MUR
MUR
MUR
MUR
MUR
105S 110S 115S 120S 140S 160S
Marking code on the device
MUR
MUR
MUR
MUR
MUR
MUR
105S
110S
115S
120S
140S
160S
UNIT
Repetitive peak reverse voltage
VRRM
50
100
150
200
400
600
V
Reverse voltage, total rms value
VR(RMS)
35
70
105
140
280
420
V
Forward current
Surge peak forward current, 8.3ms
single half sine-wave superimposed
on rated load
Junction temperature
IF
1
IFSM
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
40
1
A
35
A
Version: L2102
MUR105S – MUR160S
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJL
17
°C/W
Junction-to-lead thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
TYP
MAX
UNIT
0.875
V
1.250
V
0.710
V
MUR140S
MUR160S
1.050
V
MUR105S
MUR110S
MUR115S
MUR120S
2
µA
5
µA
50
µA
150
µA
25
ns
50
ns
MUR105S
MUR110S
MUR115S
MUR120S
SYMBOL
IF = 1A, TJ = 25°C
MUR140S
MUR160S
Forward voltage
(1)
VF
MUR105S
MUR110S
MUR115S
MUR120S
IF = 1A, TJ = 150°C
TJ = 25°C
MUR140S
MUR160S
Reverse current @ rated VR
(2)
IR
MUR105S
MUR110S
MUR115S
MUR120S
TJ = 150°C
MUR140S
MUR160S
Reverse recovery time
MUR105S
MUR110S
MUR115S
MUR120S
IF = 0.5A, IR = 1.0A
Irr = 0.25A
MUR140S
MUR160S
trr
Notes:
Pulse test with PW = 0.3ms
Pulse test with PW = 30ms
2
Version: L2102
MUR105S – MUR160S
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
MUR1xS
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
"x" defines voltage from 50V(MUR105S) to 600V(MUR160S)
3
Version: L2102
MUR105S – MUR160S
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
70
60
CAPACITANCE (pF)
1
50
40
30
MUR105S-120S
MUR140S-160S
50
75
100
125
150
175
8
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
MUR105S-120S
MUR140S-160S
0.01
TJ=25°C
10
40
50
60
70
80
24
90
100
10 10
1
UF1DLW
TJ=150°C
TJ=125°C
1
0.1
TJ=25°C
TJ=25°C
0.01
MUR105S-120S
MUR140S-160S
0.1
0.001
0.4
0.6
0.8
1.0
0.3
0.4
0.5
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width
1.2
0.7
1.4
0.8
1.6
0.9
1.8
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
50
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
TJ=150°C
0.001
Fig.4 Typical Forward Characteristics
10
0.1
16
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
12
(A)
AVERAGE FORWARD CURRENT (A)
2
8.3ms single half sine wave
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: L2102
1.2
MUR105S – MUR160S
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: L2102
MUR105S – MUR160S
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: L2102
很抱歉,暂时无法提供与“MUR120S R5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.80990
- 200+0.31342
- 500+0.30240
- 850+0.29700
