SK2S200-150
SK2S200-150
    SMCDIODESOLUTIONS(桑德斯)
    SOT-227
SK2S200-150 数据手册
SK2S200-150 Technical Data Data Sheet N1738, Rev A SK2S200-150 Power Schottky Rectifier Features International standard package SOT-227 Epoxy meets UL 94V-0 Extremely low switching losses Low IRM -values Copper internally DBC isolated This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request         SOT-227 Circuit Diagram Applications   Rectifiers in switch mode power Supplies(SMPS) Free wheeling diode in low voltage Converters Advantages      High reliability circuit operation Low voltage peaks for reduced Protection circuits Low noise switching Low losses Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Symbol Condition VRRM VRWM VR - Average Rectified Forward Current IF(AV) 50% duty cycle @TC =110°C, rectangular wave form Peak One Cycle Non-Repetitive Surge Current (Per Leg) IFSM 8.3 ms, half Sine pulse Max. Units 150 V 100(Per Leg) 200(Per Device) A 1400 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SK2S200-150 Technical Data Data Sheet N1738, Rev A Electrical Characteristics: Characteristics Symbol Forward Voltage Drop(Per Leg)* VF1 Typ. IR1 IR2 @VR = rated VR, TJ = 125 C VF2 Reverse Current(Per Leg)* Condition @ 100A, Pulse, TJ = 25 C @ 200A, Pulse, TJ = 25 C @ 100A, Pulse, TJ = 125 C @ 200A, Pulse, TJ = 125 C @VR = rated VR, TJ = 25 C Max. Units - 0.91 1.09 0.77 0.99 4 mA - 10 mA - V V * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications: Characteristics Junction Temperature Storage Temperature Thermal Resistance Junction to Case(Peg Device) Mounting torque(M4) Terminal connection torque(M4) Typical Approximate Weight Symbol TJ Tstg RJC SK2S200-150 Package SOT-227 (Pb-Free) DC operation MD - wt - Ordering Information Device Condition - Specification Units -55 to +150 -55 to +150 C C 0.4 C/W 1.1-1.5/9-13 1.1-1.5/9-13 30 Nm/ lb.in. g Marking Diagram Shipping 36pcs /BULK For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. S K 2 S 200 150 = SMC's Power Module = SOT-227 Package = Circuit Configuration = Schottky Rectifier = Forward Current (200A) = Reverse Voltage (150V)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SK2S200-150 Technical Data Data Sheet N1738, Rev A Mechanical Dimensions SOT-227(Millimeters) 38.0± 0.2 31.5± 0.1 ± 0.3 12.0 9.5± 0.1 4 2 30.2± 0.1 15.0 4-M4 4.2+0.2 -0 8± 0.2  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  25MAX 4.2 4.5± 0.3 R2.1 12.7 ∮4.2 SK2S200-150 Technical Data Data Sheet N1738, Rev A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SK2S200-150
物料型号:SK2S200-150 器件简介:SK2S200-150是一款功率肖特基整流器,具有极低的开关损耗和低正向电压降。
引脚分配:3个引脚,其中2个阳极和1个阴极。
参数特性:包括最大重复反向电压150V、工作峰值反向电压、直流阻断电压等。
功能详解:应用于开关模式电源供应器的整流器和低压转换器中的自由轮流通路二极管。
应用信息:主要应用于开关模式电源供应器的整流器和低压转换器中的自由轮流通路二极管。
封装信息:SOT-227封装,符合国际标准,无铅。
以上信息基于PDF文档中的技术数据手册提供,如需详细了解,请访问SMC Diode Solutions官方网站或联系销售部门。
SK2S200-150 价格&库存
很抱歉,暂时无法提供与“SK2S200-150”相匹配的价格&库存,您可以联系我们找货
