TSS70U
Taiwan Semiconductor
Small Signal Product
Surface Mount Schottky Barrier
FEATURES
- Designed for mounting on small surface
- Extremely thin/leadless package
- Low capacitance
- Low forward voltage drop
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21
0603
MECHANICAL DATA
- Case: 0603
- Terminal: Gold plated, solderable per
MIL-STD-750, method 2026
- Polarity: Indicated by cathode band
- Weight: 3 mg (approximately)
- Marking code: BG
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
VRRM
70
V
VR
70
V
VR(RMS)
49
V
IO
70
mA
Peak Forward Surge Current 8.3ms Single Half
Sine-Wave Superimposed on Rate Load
IFSM
100
mA
Power Dissipation
Pd
150
mW
Repetitive Peak Reverse Voltage
DC Reverse Voltage
RMS Reverse Voltage
Average Forward Current
Forward Voltage
IF = 1 mA
IF = 15 mA
VF
0.41
1.00
V
IR
0.1
μA
CJ
2
pF
trr
5
ns
Junction Temperature
TJ
-65 to +125
°C
Storage Temperature
TSTG
-65 to +125
°C
Reverse Leakage Current
VR = 25 V
Typical Capacitance Between Terminals
VR = 0 V , f = 1.0 MHz Reverse Voltage
Reverse Recovery Time
( IF= IR= 10mA, IRR= 0.1×IR, RL=100Ω )
Version: C1601
TSS70U
RATINGS AND CHARACTERISTICS CURVES
Fig.1 Forward Characteristics
Fig. 2 Reverse Characteristics
100
100
125°C
Reverse Current (μA)
Forward Current (mA)
10
10
125°C
75°C
25°C
0°C
-40°C
1
75°C
1
0.1
25°C
0.01
0.1
-40°C
0°C
0.001
75oC
0.0001
0.4
0.6
0.8
1
1.2
1.4
1.6
40
50
60
70
25oC
Reverse Voltage (V)
Forward Voltage (V)
0oC
-25 oC
Fig. 3 Capacitance Between Terminals Characteristics
120
2
f=1MHz
TA=25°C
1.6
Average Forward Current (mA)
Capacitance Between Terminals (pF)
1.8
1.4
1.2
1
0.8
0.6
0.4
0.2
Mounting on glass epoxy PCBs
100
80
Fig. 3
60
40
10
15
Reverse Voltage (V)
30
35
40
50
75
100
Ambient Temperature
125
150
(°C)
Version: C1601
TSS70U
ORDERING INFORMATION
PART NO.
PACKING CODE
TSS70U
RG
PACKING CODE
SUFFIX
PACKAGE
PACKING
0603
4K / 7" Reel
G
Note: Whole series with green compound
EXAMPLE
EXAMPLE
PART NO.
TSS70U RGG
PART NO.
PACKING CODE
TSS70U
RG
PACKING CODE
DESCRIPTION
SUFFIX
G
Green compound
PACKAGE OUTLINE DIMENSION
0603
DIM.
Unit (mm)
Unit (inch)
Min
Typ.
Max
Min
Typ.
Max
L
1.60
1.80
0.063
0.071
W
0.80
1.00
0.031
0.039
T
0.70
0.85
0.028
0.033
C
0.45
0.018
D
0.70
0.028
Version: C1601
TSS70U
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: C1601
很抱歉,暂时无法提供与“TSS70U RGG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+1.418005+0.18419
- 25+0.9395325+0.12204
- 100+0.73945100+0.09605
- 500+0.66985500+0.08701
- 4000+0.635064000+0.08249
- 国内价格
- 5+1.32357
- 25+0.87679
- 100+0.68993
- 500+0.62525
- 4000+0.59171
