S1J M2G
S1J M2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    DIODE GEN PURP 600V 1A DO214AC
S1J M2G 数据手册
S1A – S1M Taiwan Semiconductor 1A, 50V - 1000V Surface Mount Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low forward voltage drop Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 50 - 1000 V IFSM 30, 40 A TJ MAX 175 °C APPLICATIONS ● ● ● ● ● DC to DC converter Switching mode converters and inverters Lighting application Snubber General purpose Package DO-214AC (SMA) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device S1A S1B S1D S1G S1J S1K S1M UNIT S1A S1B S1D S1G S1J S1K S1M Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V Forward current Peak forward surge current, 8.3ms single half sine wave superimposed on rated load Non-repetitive peak reverse avalanche energy, IAS = 1A, L = 10mH Junction temperature Storage temperature IF 1 IFSM 40 A 30 A ERSM 5 mJ TJ - 55 to +175 °C TSTG - 55 to +175 °C 1 Version: S2102 S1A – S1M Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL S1A S1B S1D S1G S1J S1K S1M S1A S1B S1D S1G S1J S1K S1M Junction-to-lead thermal resistance Junction-to-ambient thermal resistance TYP UNIT 27 °C/W 30 °C/W 75 °C/W 85 °C/W RӨJL RӨJA ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Forward voltage (1) Reverse current @ rated VR IF = 1A, TJ = 25°C (2) Junction capacitance Reverse recovery time TJ = 25°C SYMBOL TYP MAX UNIT VF - 1.1 V - 1 µA - 50 µA CJ 12 - pF trr 1500 - ns IR TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S1x DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 50V(S1A) to 1000V(S1M) 2 Version: S2102 S1A – S1M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) 1 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 150 0.1 175 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=75°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C TJ=25°C 10.1 0.01 0.1 0.001 0.6 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.8 0.4 0.5 1.0 0.6 1.2 0.7 0.8 1.4 0.9 1.6 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 50 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 10 0.1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10 (A) AVERAGE FORWARD CURRENT (A) 2 8.3ms single half sine wave 40 30 S1A - S1K 20 S1M 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: S2102 1.2 S1A – S1M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic And Test Circuit Diagram 4 Version: S2102 S1A – S1M Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: S2102 S1A – S1M Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: S2102
S1J M2G 价格&库存
很抱歉,暂时无法提供与“S1J M2G”相匹配的价格&库存,您可以联系我们找货
