HS5A – HS5M
Taiwan Semiconductor
5A, 50V - 1000V High Efficient Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low forward voltage drop
Low profile package
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
5
A
VRRM
50 - 1000
V
IFSM
150
A
TJ MAX
150
°C
Package
DO-214AB (SMC)
Configuration
Single die
● High frequency rectification
● Freewheeling application
● Switching mode converters and inverters in computer
and telecommunication
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.210g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Junction temperature
Storage temperature
SYMBOL HS5A HS5B HS5D HS5F HS5G HS5J HS5K HS5M UNIT
VRRM
50
100
200
300
400
600
800
1000
V
VR(RMS)
35
70
140
210
280
420
560
700
V
IF
5
A
IFSM
150
A
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
1
Version: K2102
HS5A – HS5M
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
60
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
Reverse current @ rated VR
(2)
Junction capacitance
Reverse recovery time
CONDITIONS
HS5A
HS5B
HS5D
HS5F
I = 3A, TJ = 25°C
HS5G F
HS5J
HS5K
HS5M
HS5A
HS5B
HS5D
HS5F
I = 5A, TJ = 25°C
HS5G F
HS5J
HS5K
HS5M
TJ = 25°C
TJ = 125°C
HS5A
HS5B
HS5D
HS5F
1MHz, VR = 4.0V
HS5G
HS5J
HS5K
HS5M
HS5A
HS5B
HS5D
HS5F IF = 0.5A, IR = 1.0A,
HS5G Irr = 0.25A
HS5J
HS5K
HS5M
SYMBOL
VF
VF
IR
TYP
MAX
UNIT
V
V
1.35
V
1.00
V
1.30
V
1.70
V
10
µA
250
µA
80
pF
50
pF
50
ns
75
ns
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
HS5x
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(HS5A) to 1000V(HS5M)
2
Version: K2102
HS5A – HS5M
CHARACTERISTICS CURVES
Fig.2 Typical Junction Capacitance
6
175
5
150
CAPACITANCE (pF)
4
3
2
1
125
100
HS5A - HS5G
75
50
HS5J - HS5M
25
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
0.1
150
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=125°C
10
TJ=25°C
1
30
40
50
60
70
80
90
100
10 10
HS5A - HS5D
UF1DLW
1
TJ=125°C
1
0.1
TJ=25°C
HS5G
HS5J - HS5M
0.01
0.1
0.001
0.4
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.6
0.4
0.5
0.8
0.6
1.0
0.7
0.8
1.2
0.9
1.4
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
200
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
1000
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
Fig.1 Forward Current Derating Curve
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: K2102
1.2
HS5A – HS5M
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: K2102
HS5A – HS5M
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: K2102
HS5A – HS5M
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2102
很抱歉,暂时无法提供与“HS5F R7G”相匹配的价格&库存,您可以联系我们找货
