SR30150PTHC0G
SR30150PTHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO247
    DIODE ARRAY SCHOTTKY 150V TO247
SR30150PTHC0G 数据手册
SR3020PT – SR30150PT Taiwan Semiconductor 30A, 20V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 30 A VRRM 20 - 150 V IFSM 300 A TJ MAX 125, 150 °C APPLICATIONS ● ● ● ● ● Package TO-247AD (TO-3P) Configuration Dual dies Switching mode power supply (SMPS) Adapters Monitor DC to DC converters TV MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-247AD (TO-3P) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 1.13 N⋅m maximum Polarity: As marked Weight: 6.10g (approximately) TO-247AD (TO-3P) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SR SR SR SR SR SR SR SR SYMBOL 3020 3030 3040 3050 3060 3090 30100 30150 UNIT PT PT PT PT PT PT PT PT SR SR SR SR SR SR SR SR 3020 3030 3040 3050 3060 3090 30100 30150 PT PT PT PT PT PT PT PT VRRM 20 30 40 50 60 90 100 150 V VR(RMS) 14 21 28 35 42 63 70 105 V IF 30 A IFSM 300 A TJ -55 to +125 TSTG -55 to +150 -55 to +150 1 °C °C Version: H2103 SR3020PT – SR30150PT Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 1.5 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse current @ rated VR (2) per diode SR3020PT SR3030PT SR3040PT SR3050PT SR3060PT IF = 15A, TJ = 25°C SR3090PT SR30100PT SR30150PT SR3020PT SR3030PT SR3040PT SR3050PT TJ = 25°C SR3060PT SR3090PT SR30100PT SR30150PT SR3020PT SR3030PT SR3040PT SR3050PT TJ = 100°C SR3060PT SR3090PT SR30100PT SR30150PT SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.90 V - 1.00 V - 1000 µA - 500 µA - 20 mA - 15 mA - 10 mA IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SR30xPT TO-247AD (TO-3P) 30 / Tube SR30xPTH TO-247AD (TO-3P) 30 / Tube Notes: 1. “x” defines voltage from 20V(SR3020PT) to 150V(SR30150PT) 2. “H” means AEC-Q101 qualified 2 Version: H2103 SR3020PT – SR30150PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SR3050PT-30150PT 25 20 SR3020PT-3040PT 15 10 SR3020PT-3040PT 1000 SR3050PT-3060PT 100 SR3090PT-30150PT 5 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C TJ=75°C 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 100010 SR3090PT-30100PT SR3050PT-3060PT UF1DLW 100 1 SR3020PT-3040PT TJ=125°C TJ=25°C 10 0.1 1 0.01 SR30150PT 0.1 0.001 0.2 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.4 0.4 0.5 0.6 0.6 0.7 0.8 0.8 0.9 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 350 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) 30 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 35 300 8.3ms single half sine wave 250 200 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: H2103 1.2 SR3020PT – SR30150PT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: H2103 SR3020PT – SR30150PT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-247AD (TO-3P) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: H2103 SR3020PT – SR30150PT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2103
SR30150PTHC0G 价格&库存
很抱歉,暂时无法提供与“SR30150PTHC0G”相匹配的价格&库存,您可以联系我们找货
