2CZ4004 – 2CZ4005
Taiwan Semiconductor
1A, 400-600V Rectifiers
FEATURES
KEY PARAMETERS
● Surface mount device type
● Low peakage current
● Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
UNIT
IF(AV)
1
A
VRRM
400-600
V
IFSM
7.5
A
VF at IF=1A
1.1
V
TJ MAX
● The devices are designed for high frequency miniatures switched
Mode power supplies such as adapters, lighting and on-board
DC/DC converters.
MECHANICAL DATA
150
°C
Package
SOD-123
Configuration
Single dice
mm
Case: SOD-123 small outline plastic package
Molding compound meets UL 94 V-0 flammability rating
Moisture sensitivity level: level 1, per J-STD-020
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: Indicated by cathode band
Weight: 9.5 mg (approximately)
eco
VALUE
en
de
d
APPLICATIONS
PARAMETER
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
SYMBOL
No
tR
PARAMETER
Marking code on the device
Non-repetitive peak reverse voltage
@IR=100uA
RMS reverse voltage
Forward current
Non-repetitive peak forward surge current
8.3ms half sine wave
Power dissipation
2CZ4004
2CZ4005
UNIT
Z44
Z45
VRRM
400
600
V
VR(RMS)
IO
280
420
V
1
A
IFSM
7.5
A
PD
350
mW
Juncion temperature range
TJ
- 55 to +150
°C
Storage temperature range
TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
RӨJA
357
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version:G1702
2CZ4004 – 2CZ4005
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
Forward voltage per diode
(1)
TYP
MAX
UNIT
VF
1.1
V
IR
5
µA
CJ
15
pF
IF = 1A, TJ = 25°C
VR=400V, TJ = 25°C
Reverse current @ rated VR per
diode
SYMBOL
(2)
VR=600V, TJ = 25°C
1 MHz, VR=4V
en
de
d
Junction capacitance
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
ORDERING INFORMATION
PACKING
PACKING CODE
CODE
SUFFIX
RH
G
2CZ4004
2CZ4005
EXAMPLE
e co
Notes:
1. Whole series with green compound
PACKAGE
PACKING
SOD-123
3K / 7" Reel
mm
PART NO.(Note. 1)
PART NO.
PACKING CODE
2CZ4004 RHG
2CZ4004
RH
PACKING CODE
SUFFIX
G
DESCRIPTION
Green compound
No
tR
EXAMPLE P/N
2
Version:G1702
2CZ4004 – 2CZ4005
CHARACTERISTICS CURVES
Fig. 1 Typical Forward Characteristics
Fig. 2 Reverse Characteristics
1000
TA=25°C
100
d
10
TA=100°C
TA=25°C
de
TA=100°C
en
100
Reverse Current (nA)
Instantaneous Forward Current (mA)
1000
1
10
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
1.2
200
300
400
500
600
Reverse Voltage (V)
mm
Instantaneous Forward Voltage (V)
f=1MHz
tR
15
Power Dissipation (mW)
400
10
No
Capacitance between terminals (pF)
Fig. 4 Power Derating Curve
e co
Fig. 3 Capacitance Characteristics
5
10
Reverse Voltage (V)
15
300
200
100
50
75
100
125
150
Ambient Temperature (°C)
3
Version:G1702
2CZ4004 – 2CZ4005
PACKAGE OUTLINE DIMENSION
SOD-123
DIM.
Unit(mm)
Unit(inch)
Max
Min
Max
A
1.40
1.80
0.055
0.071
B
3.55
3.85
0.140
0.152
C
0.45
0.70
0.018
0.028
D
2.55
2.85
0.100
0.112
E
0.95
1.35
0.037
0.053
F
0.05
0.15
0.002
0.006
0.10
G
0.50 REF
0.02 REF
de
0.004
Unit(mm)
Unit(inch)
Min
Min
G
2.25
0.089
DIM.
X
0.90
0.035
X1
4.05
0.159
Y
0.95
0.037
No
tR
e co
SUGGEST PAD LAYOUT
mm
en
H
d
Min
4
Version:G1702
2CZ4004 – 2CZ4005
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version:G1702
很抱歉,暂时无法提供与“2CZ4005 RHG”相匹配的价格&库存,您可以联系我们找货
