SD103BWSATR
SD103BWSATR
    SMCDIODESOLUTIONS(桑德斯)
    SC76
    DIODE SCHOTTKY 30V 100MA SOD323
SD103BWSATR 数据手册
CMDSH-3 Technical Data Data Sheet N1562, Rev. B CMDSH-3 SCHOTTKY BARRIER DIODE Features CMDSH-3 type is a silicon Schottky diode, manufactured in a surface mount package, designed for fast switching applications requiring a low forward voltage drop. SOD-323 Schematic & Pin Configuration Mechanical Characteristics     Case: SOD-323, Molded plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.04 grams(approx) Maximum Ratings @TA=25°C unless otherwise specified Characteristic Symbol Value Units VRRM 30 V Average Forward Current IO 100 mA Power Dissipation PD 250 mW Power Dissipation(TL = 25°C) PD 833 mW Peak Forward Surge Current (tp=8.3ms) IFSM 750 mA Operating Junction Temperature Range TJ -65 to +150 °C Storage Temperature Range TSTG -65 to +150 °C Thermal Resistance RΘJA 500 °C/W Thermal Resistance RΘJL 150 °C/W Peak Reverse Voltage Note: 1. Valid provided that terminals are kept at ambient temperature.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  CMDSH-3 Technical Data Data Sheet N1562, Rev. B Electrical Characteristics @TA=25°C unless otherwise specified Characteristics Forward Voltage Drop* Reverse Recovery Voltage* Reverse Current* Typical Junction Capacitance Symbol VF VBR IR Cj Condition @IF = 50mA,TA = 25°C @IF = 100mA,TA = 25°C @IF = 100uA @VR = 25V, TJ = 25 C @VR =10.0 V, Tc=25C, fSIG = 1MHz Min 30 - * Pulse width < 300 µs, duty cycle < 2% Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Typ. 7.0 Max. 0.55 0.80 10 - Units V V uA pF CMDSH-3 Technical Data Data Sheet N1562, Rev. B Ordering Information Marking Diagram Device Package Shipping CMDSH-3 SOD-323 (Pb-Free) 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. S1 = Marking Code Mechanical Dimensions SOD-323 SYMBOL Millimeters Inches MIN. MAX. MIN. MAX. A A1 A2 b 0.000 0.800 0.250 1.000 0.100 0.900 0.350 0.000 0.031 0.010 0.039 0.004 0.035 0.014 c 0.080 0.150 0.003 0.006 D E E1 L L1 θ 1.200 1.400 1.600 1.800 2.500 2.700 0.475 REF. 0.250 0.400 0° 8° 0.047 0.055 0.063 0.071 0.098 0.106 0.019 REF. 0.010 0.016 0° Carrier Tape Specification SOD-323 SYMB OL B C d E F P P0 P1 W Min. Millimeters 2.85 1.20 1.40 1.65 3.40 3.90 3.90 1.90 7.90  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  Max. 2.95 1.30 1.60 1.85 3.60 4.10 4.10 2.10 8.30 8° CMDSH-3 Technical Data Data Sheet N1562, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SD103BWSATR 价格&库存
很抱歉,暂时无法提供与“SD103BWSATR”相匹配的价格&库存,您可以联系我们找货
