C3D06065A
C3D06065A
    WOLFSPEED
    TO-220-2
    C3D06065A
C3D06065A 数据手册
C3D06065A VRRM Silicon Carbide Schottky Diode IF (TC=135˚C) Z-Rec Rectifier ® = 9A Package 650-Volt Schottky Rectifier Zero Reverse Recovery Current Zero Forward Recovery Voltage High-Frequency Operation Temperature-Independent Switching Behavior Extremely Fast Switching Positive Temperature Coefficient on VF TO-220-2 Benefits • • • • • 650 V Qc =   15 nC Features • • • • • • • = Replace Bipolar with Unipolar Rectifiers Essentially No Switching Losses Higher Efficiency Reduction of Heat Sink Requirements Parallel Devices Without Thermal Runaway PIN 1 CASE PIN 2 Applications • • • Switch Mode Power Supplies Power Factor Correction Motor Drives Part Number Package Marking C3D06065A TO-220-2 C3D06065 Maximum Ratings (TC = 25 ˚C unless otherwise specified) Symbol Parameter Unit Test Conditions Note VRRM Repetitive Peak Reverse Voltage 650 V VRSM Surge Peak Reverse Voltage 650 V VDC DC Blocking Voltage 650 V Continuous Forward Current 19 9 6 A TC=25˚C TC=135˚C TC=154˚C IFRM Repetitive Peak Forward Surge Current 30 20 A TC=25˚C, tP = 10 ms, Half Sine Wave TC=110˚C, tP = 10 ms, Half Sine Wave IFSM Non-Repetitive Peak Forward Surge Current 63 49 A TC=25˚C, tp = 10 ms, Half Sine Wave TC=110˚C, tp = 10 ms, Half Sine Wave Fig. 8 IF,Max Non-Repetitive Peak Forward Surge Current 540 460 A TC=25˚C, tP = 10 µs, Pulse TC=110˚C, tP = 10 µs, Pulse Fig. 8 Ptot Power Dissipation 88 38 W TC=25˚C TC=110˚C Fig. 4 -55 to +175 ˚C 1 8.8 Nm lbf-in IF TJ , Tstg Operating Junction and Storage Temperature TO-220 Mounting Torque 1 Value C3D06065A Rev. C, 12-2015 M3 Screw 6-32 Screw Fig. 3 Electrical Characteristics Symbol Parameter Typ. Max. Unit Test Conditions Note VF Forward Voltage 1.5 2.0 1.7 2.4 V IF = 6 A TJ=25°C IF = 6 A TJ=175°C Fig. 1 IR Reverse Current 8 15.5 40 160 μA VR = 650 V TJ=25°C VR = 650 V TJ=175°C Fig. 2 QC Total Capacitive Charge 15 nC VR = 400 V, IF = 6 A di/dt = 500 A/μs TJ = 25°C Fig. 5 C Total Capacitance 295 28.5 25.5 pF VR = 0 V, TJ = 25°C, f = 1 MHz VR = 200 V, TJ = 25˚C, f = 1 MHz VR = 400 V, TJ = 25˚C, f = 1 MHz Fig. 6 EC Capacitance Stored Energy 2.3 μJ VR = 400 V Fig. 7 Note: This is a majority carrier diode, so there is no reverse recovery charge. Thermal Characteristics Symbol RθJC Parameter Thermal Resistance from Junction to Case Typ. Unit Note 1.7 °C/W Fig. 9 Typical Performance 20 14 8 6 TJ = 25 °C TJ = 75 °C TJ = 125 °C IR (mA) 10 TJ = -55 °C Reverse Leakage Current, IRR (mA) F Foward I Current, (A) IF (A) 12 TJ = 175 °C 4 2 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 0 200 400 600 800 1000 1200 FowardVVoltage, (V) VF (V) F Figure 1. Forward Characteristics 2 C3D06065A Rev. C, 12-2015 3.5 4.0 16 TJ = 175 °C 12 TJ = 125 °C TJ = 75 °C 8 TJ = 25 °C TJ = -55 °C 4 0 0 100 200 300 400 500 600 700 800 900 1000 ReverseVVoltage, (V) VR (V) R Figure 2. Reverse Characteristics Typical Performance 70 100 10% Duty 20% Duty 30% Duty 50% Duty 70% Duty DC 60 80 70 40 (W) PP Tot(W) TOT IF(peak) (A) IF (A) 50 90 30 60 50 40 30 20 20 10 10 0 25 50 75 100 125 150 0 175 25 50 75 T ˚C TCC(°C) 150 175 C Figure 4. Power Derating 350 Conditions: TJ = 25 °C Conditions: TJ = 25 °C Ftest = 1 MHz Vtest = 25 mV 300 20 250 Capacitance C (pF) (pF) CapacitiveQCharge, (nC) QC (nC) C 125 ˚C TTC (°C) Figure 3. Current Derating 25 100 15 10 200 150 100 5 50 0 0 100 200 300 400 500 600 ReverseVVoltage, (V) VR (V) R Figure 5. Total Capacitance Charge vs. Reverse Voltage 3 C3D06065A Rev. C, 12-2015 700 0 0 1 10 100 (V) VR (V) ReverseVVoltage, R Figure 6. Capacitance vs. Reverse Voltage 1000 Typical Performance 1,000 6 IIFSM (A) (A) 4 FSM 3 C Capacitance StoredE Energy, µJ) (mJ) EC (µ 5 100 TJ_initial = 25 °C TJ_initial = 110 °C 2 1 0 0 100 200 300 400 500 600 10 10E-6 700 ReverseVVoltage, (V) VR (V) Figure 8. Non-repetitive peak forward surge current versus pulse duration (sinusoidal waveform) Figure 7. Capacitance Stored Energy Thermal Resistance (oC/W) Thermal Resistance (˚C/W) 1E-3 tp (s) Time, tp (s) R 1 100E-6 0.5 0.3 0.1 100E-3 0.05 0.02 SinglePulse 10E-3 0.01 1E-3 1E-6 10E-6 100E-6 1E-3 Time, tp (s) T (Sec) 10E-3 Figure 9. Transient Thermal Impedance 4 C3D06065A Rev. C, 12-2015 100E-3 1 10E-3 Package Dimensions Package TO-220-2 POS PIN 1 PIN 2 CASE Inches Millimeters Min Max Min Max A .381 .410 9.677 10.414 B .235 .255 5.969 6.477 C .100 .120 2.540 3.048 D .223 .337 5.664 8.560 D1 .457-.490 11.60-12.45 typ D2 .277-.303 typ 7.04-7.70 typ D3 .244-.252 typ 6.22-6.4 typ E .590 .615 14.986 15.621 E1 .302 .326 7.68 8.28 E2 .227 251 5.77 6.37 F .143 .153 3.632 3.886 G 1.105 1.147 28.067 29.134 H .500 .550 12.700 13.970 L .025 .036 .635 .914 M .045 .055 1.143 1.550 N .195 .205 4.953 5.207 P .165 .185 4.191 4.699 Q .048 .054 1.219 1.372 S 3° 6° 3° 6° T 3° 6° 3° 6° U 3° 6° 3° 6° V .094 .110 2.388 2.794 W .014 .025 .356 .635 X 3° 5.5° 3° 5.5° Y .385 .410 9.779 10.414 z .130 .150 3.302 3.810 NOTE: 1. Dimension L, M, W apply for Solder Dip Finish Recommended Solder Pad Layout TO-220-2 Part Number Package Marking C3D06065A TO-220-2 C3D06065A Note: Recommended soldering profiles can be found in the applications note here: http://www.wolfspeed.com/power_app_notes/soldering 5 C3D06065A Rev. C, 12-2015 Diode Model Diode Model CSD04060 Vf T = VT + If*RT VT= 0.965 + (Tj * -1.3*10-3) RT= 0.096 + (Tj * 1.06*10-3) VfT = VT + If * RT VT = 0.96 + (TJ * -1.1*10-3) RT = 0.07 + (TJ * 7.4*10-4) VT RT Note: Tj = Diode Junction Temperature In Degrees Celsius, valid from 25°C to 175°C Notes • RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Wolfspeed representative or from the Product Ecology section of our website at http://www.wolfspeed.com/power/tools-and-support/product-ecology. • REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. • This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, or air traffic control systems. Related Links • • • Cree SiC Schottky diode portfolio: http://www.wolfspeed.com/Power/Products#SiCSchottkyDiodes Schottky diode Spice models: http://www.wolfspeed.com/power/tools-and-support/DIODE-model-request2 SiC MOSFET and diode reference designs: http://go.pardot.com/l/101562/2015-07-31/349i Copyright © 2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 6 C3D06065A Rev. C, 12-2015 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
C3D06065A 价格&库存
很抱歉,暂时无法提供与“C3D06065A”相匹配的价格&库存,您可以联系我们找货
C3D06065A
  • 1+34.942421+4.51078
  • 50+17.6568950+2.27936
  • 100+15.98250100+2.06321
  • 500+13.04513500+1.68402
库存:612
