Quartz Crystal, Series TX2
SMD Seam Sealed Crystals
2.5×2.0×0.55 mm
Feature
Size 2.5 × 2.0 , Ultra thin , thickness 0.55mm
High precision and high frequency stability
Excellent heat resistance and environmental characteristics
Designed for automatic mounting and reflow soldering
RoHS Compliant / Pb Free
Electrical Specifications
Item
Specifications
Frequency Range(MHZ)
12~24
24~54
Mode
AT/Fundamental
Load Capacitance (CL)
8pF, 10pF, 12pF or Specify
Frequency Tolerance( at 25°C )
±10ppm ~ ±30ppm or specify
Operating Temperature Range
-20~+70°C or Specify
Frequency Stability Over Operating Temperature Range
±10ppm ~ ±50ppm or specify
Equivalent Series Resistance (ESR) max.
60Ω
80Ω
Storage Temperature Range
-55~+125°C
Shunt Capacitance( C 0 )
3pF Max
Drive Level (Typical)
1 ~100 μW (10μW typical)
Aging @ 25°C 1st Year (Max)
±3 ppm/year
Dimension(mm)
0.55 MAX
2.00±0.1
2.50±0.1
1.0
0.85
1.0
0.9
0.7
0.65
0.9
0.9
http://www.wtlcrystals.com
Email:wtl@wtlcrystals.com
Tel:86-755-82677582
04
很抱歉,暂时无法提供与“WTL2M60414VH”相匹配的价格&库存,您可以联系我们找货
