CMG532 12M0A30-10-50-40-80TLH
    NEXTGEN
    SMD-2
    无源晶振 12MHz 80Ω 10pF ±30ppm -40℃~+85℃ SMD-2
CMG532 12M0A30-10-50-40-80TLH 数据手册
PART CODE: XR12M00000S101 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0207-XR12M00000S101 DATE Feb. 07, 2021 REVISION A0 DESCRIPITION SMD Crystal, Ceramic Cover, Glass seal, 5032 Type, 2 pads, 12.0000MHz, +/-30ppm, CL 10pF, Stability +/-50ppm @Operating Temp. Range -40°C ~+85°C, ESR 80 ohm Max, Tape/Reel, Reflow Profile Condition 260 °C Max. RoHS/RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863) CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS CMG532 12M0A30-10-50-40-80TLH PART CODE XR12M00000S101 VENDOR APPROVE Issued/Checked/Approved DATE: Feb. 07, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XR12M00000S101 SMD CRYSTAL GLASS SEAL 5032 TYPE 2 PADS MAIN FEATURE • SMD Crystal, Glass Seal, Ceramic Cover, 5.0*3.2mm, 2 pads • Low cost, High precision, High frequency stability • Reflow Profile Condition 260 °C Max. • Cross more competitors part • RoHS/RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863 APPLICATION • Bluetooth, wireless communication set • Communication Electronics RFQ PART CODE GUIDE Request For Quotation XR 12M00000 S 101 1 2 3 4 1) XR: Part family Code for SMD Crystal, Glass seal, 5032 type, 2 pads (CMG532) 2) 12M00000: Frequency range code for 12.0000MHz 3) S: SMD type, Package Tape/Reel, 1000pcs/Reel 4) 101: Specification code for original part no. TGS CMG532 12M0A30-10-50-40-80TLH MORE FREQUENCY RANGE AVAILABLE (MHz) 8.0000 12.0000 25.0000 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XR12M00000S101 SMD CRYSTAL GLASS SEAL 5032 TYPE 2 PADS DIMENSION (Unit: mm, Tol. +/-0.15mm) Image for reference Marking Line 1: Company Code + CL value Line 2: Freq. Range+ QC Code (A~Z) CMG532 Connection #1 Crystal #2 Crystal Alternative bottom packaging Recommend Pad Layout NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XR12M00000S101 SMD CRYSTAL GLASS SEAL 5032 TYPE 2 PADS ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Original Manufacturer Holder Type Frequency Range Typical Condition Max. TGS TGS Crystals CMG532 SMD Crystal, Glass Seal, L5.0*W3.2*H1.2mm, 2 pads 12M0 MHz 12.000 Mode of Oscillation A Frequency Tolerance 30 ppm Load Capacitance -10 pF Stability over Operation Temperance -50 ppm -50 +50 Operation Temperance -40 °C -40 +85 °C -55 +125 Storage Temperance Equivalent Series Resistance (ESR) -80 AT Fundamental -30 +30 10 Ω 80 Drive Level μW 300 Shunt Capacitance (C0) pF Motional Capacitance (C1) fF N/A DLD2 Ω N/A FLD2 ppm N/A RDL2 Ω N/A SPDB dB N/A Aging ppm/year Insulation Resistance MΩ 0 5.0 ±3 500 @1st year @100VDC ± 15VDC Package T Tape/Reel RoHS Status LH RoHS III compliant, RoHS Annex III lead Exemption (exempt per RoHS EU 2015/863 Others @25°C Add Value N/A Internal Control Code * N/A Note: 1) Original Part Number: TGS CMG532 12M0A30-10-50-40-80TLH 2) * Internal Control Code- 2 letter or digits; Blank: N/A NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XR12M00000S101 SMD CRYSTAL GLASS SEAL 5032 TYPE 2 PADS RELIABILITY Test Items Test Method And Conditions Reference Documents High Temperature High Humidity Storage Temperature: 85℃±3℃ Relative Humidity:85%RH Time: 96 Hours JIS C5023 High Temperature Storage Temperature: 125℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1005.8 Low Temperature Storage Temperature: -40℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1013 Thermal Shock Temperature 1: -55℃±5℃ Temperature 2: 85℃±5 ℃ Temperature change between T1 and T2 5 min 10cycles maintain T1 and T2 for 30 minutes each cycle MIL-STD-202F Method 107 Condition A Resistance to Solder Heat Solder Temperature: 260℃±5℃ Time: 10±1 Seconds MIL-STD-202F Method 210E Solderability The solder pot temperature is 245±5℃ , dwell time 5±0.5sec J-STD-002B Drop Test 3 Times Free Fall from 50cm height table to 3cm thickness hard wood board J-STD-002B Mechanical Shock Half sine wave,1000 G 3 Times for all 3 directions(X,Y Z) MIL STD 202F Method 213B Vibration Frequency Range: 10Hz~55Hz Amplitude: 0.75mm 2 Hours in each direction, total 6 Hours MIL-STD-883E Method 2007.3 Leakage Test Take measurements with a helium Leakage detector Leakage Rate≤1×10ˉ³Pa cm³/s MIL-STD-883E NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XR12M00000S101 SMD CRYSTAL GLASS SEAL 5032 TYPE 2 PADS SUGGESTED REFLOW PROFILE (For Reference Only) Total time: 200 Sec. Max. Solder melting point: 220℃ Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 125℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 260 ℃ Time within 5℃ of actual Peak Temperature (tp) 20~40 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 8 minutes Max. Suggest reflow times 3 Times Max. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: XR12M00000S101 SMD CRYSTAL GLASS SEAL 5032 TYPE 2 PADS TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-2 and specifications., 1000pcs/Reel Item Dimension A 1.70 B 5.45 C 3.65 D 8.00 E 12.0 DISCLAIMER NextGen Components, Inc.. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
CMG532 12M0A30-10-50-40-80TLH 价格&库存
很抱歉,暂时无法提供与“CMG532 12M0A30-10-50-40-80TLH”相匹配的价格&库存,您可以联系我们找货
