SXT32418DC27-16.384MT
    SUNTSU
    SMD3225_4P
    无源晶振 18pF 70Ω ±20ppm 16.384MHz -20℃~+70℃ SMD3225_4P
SXT32418DC27-16.384MT 数据手册
Ceramic SMT 4 Pad Crystal SXT324 Series 3.2mm x 2.5mm Features Applications • ±10ppm/±10ppm (Tolerance/Stability) Available • High Density Applications • Ultra-Miniature Package • Wireless Applications • PCMCIA • AT-Cut Fundamental • Computers and Modems • Tape and Reel Part Numbering Guide SXT 32 4 18 A A 48 T - 20.000M FREQUENCY MHz MODE OF OPERATION Blank : Fundamental OPERATING TEMPERATURE T : 3rd Overtone SUNTSU CRYSTAL 3.2mm x 2.5mm 4 PAD LOAD CAPACITANCE FREQUENCY STABILITY FREQUENCY TOLERANCE S : Series A : ±50ppm A : ±50ppm COMPLIANT 7-32 : 7pF - 32pF B : ±30ppm B : ±30ppm C : ±25ppm C : ±25ppm D : ±20ppm D : ±20ppm E : ±15ppm E : ±15ppm Cage Code: 4GUT4 F : ±10ppm* F : ±10ppm To customize your parameters contact a Suntsu representative. RANGE** 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C * For frequency stability option F contact a Suntsu representative. ** For operating temperatures of -55-125°C a Suntsu representative. Electrical Parameters Frequency Range Units Minimum MHz 10 Typical Maximum 70 AT-Cut Fundamental. Remarks Frequency Range MHz 60 170 3rd Overtone Frequency Tolerance at +25ºC ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Op Temp ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Aging ppm -2 +2 First year @ +25ºC. Operating Temperature °C -40 +85 Storage Temperature °C -40 +125 Load Capacitance pF 7 32 Shunt Capacitance pF Drive Level µW Insulation Resistance MΩ 10.000MHz ~ 12.000MHz 16.000MHz ESR - 20.000MHz See part numbering guide for options. See part numbering guide for options. 5 10 50 100 500 @ 100VDC ± 15V. 11.999MHz Ω 250 AT-Cut Fundamental ~ 15.999MHz Ω 100 AT-Cut Fundamental ~ 19.999MHz Ω 70 AT-Cut Fundamental ~ 29.999MHz Ω 50 AT-Cut Fundamental 30.000MHz 49.999MHz 40.000MHz ~ 66.000MHz 40 50 AT-Cut Fundamental 50.000MHz ~ 70.000MHz Ω Ω Ω AT-Cut Fundamental 60.000MHz ~ 170.000MHz Ω 35 80 3rd Overtone Outline Drawing & Recommended Landed Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad Crystal SXT324 Series 3.2mm x 2.5mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K Moisture Resistance MIL-STD-883, Method 1004 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Solderability MIL-STD-883, Method 2003 Reflow Profile & Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 3,000pcs / Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
物料型号:SXT324 Series
器件简介:SUNTSU的SXT324系列是一款超小型封装的表面贴装陶瓷谐振器,尺寸为3.2mm x 2.5mm,适用于高密度应用,如PCMCIA、无线应用、计算机和调制解调器。
引脚分配:4 Pad配置,具体引脚分配未在文档中详述。
参数特性: - 频率范围:10MHz至70MHz(基础切割)和60MHz至170MHz(第三泛音) - 频率容差:±10ppm至±50ppm,具体取决于型号 - 频率稳定性:±10ppm至±50ppm,具体取决于型号 - 负载电容:7pF至32pF - 工作温度范围:-40°C至+85°C,具体取决于型号 - 存储温度:-40°C至+125°C - 绝缘电阻:至少500MΩ(在100VDC±15V下)
功能详解:文档中未提供详细的功能解释,但通常这类谐振器用于为电子设备提供稳定的时钟信号。
应用信息:适用于高密度应用,如PCMCIA、无线应用、计算机和调制解调器。
封装信息:超小型封装,适用于表面贴装技术(SMT),并提供卷带包装,每卷3000件。
SXT32418DC27-16.384MT 价格&库存
很抱歉,暂时无法提供与“SXT32418DC27-16.384MT”相匹配的价格&库存,您可以联系我们找货
