S51810T-27.000-X1-CT 数据手册
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Ltr
Date
Revisions
Appr
Electrical Specifications:
Frequency Range
8.000 to 133.000
MHz
Fundamental
8.000 to 54.000
MHZ
Third Overtone
40.000 to 133.000
±50
PPM Max
±100
PPM Max
-40 to +125
ºC
-55 to +125
PPM Max/Year
±3
10 to 32 and Series Resonance
pF
7.0
See ESR Table
Ohm
100
uW Typ
500 at at 100 Vdc ± 15 Vdc
M Ohm
Mode of Oscillation
Frequency Tolerance at 25°C
Frequency Stability over Temperature Range
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
Frequency Range and ESR Values:
Frequency Range in MHz
8.000 to 9.749
ESR Ohm Max Mode of Operation
70
Fundamental
40.000 to 79.999
100
3rd Overtone
9.750 to 9.999
60
Fundamental
80.000 to 99.999
80
3rd Overtone
10.000 to 11.999
45
Fundamental
100.000 to 133.000
60
3rd Overtone
12.000 to 15.999
35
Fundamental
16.000 to 19.999
30
Fundamental
20.000 to 49.999
25
Fundamental
50.000 to 54.000
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: May 1, 2017
Microprocessor Crystal Unit
Automotive Temperature Range
5.0 x 3.2 millimeter Surface Mount
General Product Specification
Part Number:
C5S X1 Series
www.aker-usa.com
Mechanical Outline:
5.0 ± 0.15
Ceramic Base
3.2 ± 0.15
#4
Metal Lid
#3
AKER
#1
#2
1.0 Max.
2.6
3.8
#2
#4
#3
1.4
0.9
1.4
2.3
#1
1.2
#2:GND #4:GND
1.6
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: May 1, 2017
P/N:
www.aker-usa.com
C5S X1 Series
1.5
2.0
1.75
Carrier Tape Dimensions:
4.0
B-B SECTION
5.4
AKER
AKER
AKER
AKER
A
12.0
5.5
B
A
B
1.5
8.0
1.4
3.6
A-A SECTION
Solder Reflow Characteristics:
Page:
3/4
Date: May 1, 2017
P/N:
www.aker-usa.com
C5S X1 Series
How to build a Part Number:
Series
Package
C
5S
Frequency
8.000 to 133.000
Load Capacitance
Frequency Tolerance
Frequency Stability
Mode of Oscillation
7
10
12
16
18
S
See Notes
3
X1
Packaging
M
R
50
100
Temperature Range
Parameter
5.0 x 3.2 mm
MHz
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
±50 PPM
±100 PPM
Fundamental
Third Overtone
-40 to +125 ºC
250pcs Reel
1000pcs Reel
Part Number Example:
C5S-40.000-50100-X1-R
C5S: 5.0 x 3.2 mm SMD Seam Sealed Package
40.000 MHz Nominal Frequency
18 pF Load Capacitance
50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability
X1: -40 to +125º C Extended Temperature Range
R: Tape and Reel Packaging - 1000pcs reel
Notes:
1- Fundamental mode does not need to be included in Part Number description.
2- Other Load Capacitances are availble other than those listed in Part Number table above.
3- Product is shipped in Tape and Reel configuration.
4- Quantities less than 250pcs are shipped in tape
5- Specification subject to change without notice
Page:
4/4
Date: May 1, 2017
P/N:
C5S X1 Series
www.aker-usa.com
S51810T-27.000-X1-CT 价格&库存
很抱歉,暂时无法提供与“S51810T-27.000-X1-CT”相匹配的价格&库存,您可以联系我们找货
