7V-20.500MAAE-T
7V-20.500MAAE-T
    TXC(台晶)
    SMD-4
    无源晶振 12pF 20.5MHz ±30ppm 60Ω -20℃~+70℃ SMD-4
7V-20.500MAAE-T 数据手册
7V MHz Crystal Features Frequency range : 9.9MHz to 54MHz Glass sealing, ceramic SMD package External dimensions (mm) L : 3.2 x W : 2.5 x H : 0.8 RoHS compliant Contains Pb, exempted by RoHS directive Applications PC, TV, Game, Camera Notebook, Hard disk Computer peripherals Home electronics Consumer products Electrical Characteristics Item 7V Frequency Range F0 9.9MHz ~ 54MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±50 ppm ±30 ppm ±20 ppm ±60 ppm -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 Drive Level DL Load Capacitance CL 6pF, 7pF, 8pF, 9pF, 10pF 12pF, 16pF, 18pF, 20pF Aging Faging ±3 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C 3pF Max. 1 ~ 50μW (10μW Typ.) at 25°C ± 3°C,first year Motional Resistance (ESR) Fundamental 9.9 ~ 12 MHz 12 ~ 16 MHz 16 ~ 54 MHz Rev. 1.04 150Ω Max. 100Ω Max. 60Ω Max. Page 1 www.txccrystal.com 7V MHz Crystal Dimensions Ordering Information 7V - 27.000M A H E Frequency in Hz - T Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E ± 30 ppm ± 20 ppm ± 10 ppm Frequency Stability (over Temp.) A D E T G H I K Rev. 1.04 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 50 ppm ± 30 ppm ± 20 ppm ± 60 ppm B Y V C Q E I J 6 pF 7 pF 8 pF 9 pF 10 pF 12 pF 16 pF 18 pF ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.txccrystal.com 7V MHz Crystal Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 5°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.04 60 sec Page 3 Time (sec) www.txccrystal.com
7V-20.500MAAE-T
物料型号:7V 27.000M A H E 器件简介:晶体振荡器,采用RoHS兼容的玻璃密封陶瓷SMD封装,尺寸为3.2 x 2.5 x 0.8毫米。 引脚分配:文档中未明确提供引脚分配图,但通常晶体振荡器有4个引脚,包括两个电源引脚和两个输出引脚。 参数特性:频率范围9.9MHz至54MHz,频率容差±30ppm至±10ppm,工作温度范围从-40°C至+125°C,负载电容6pF至20pF,老化±3ppm。 功能详解:文档中未提供详细的功能描述,但晶体振荡器通常用于为电子设备提供稳定的时钟信号。 应用信息:适用于笔记本电脑、硬盘驱动器、电视、游戏机、相机等消费电子产品和计算机外围设备。 封装信息:3.2+0.1mm x 2.5mm x 0.8mm,建议的布局和连接方式在文档中有图示说明。
7V-20.500MAAE-T 价格&库存
很抱歉,暂时无法提供与“7V-20.500MAAE-T”相匹配的价格&库存,您可以联系我们找货
