TCVCXO Specification
Part No. + Packaging: LFTVXO063789Bulk
Customer Part:
Description
Temperature compensated voltage controlled crystal oscillator
(TCVCXO)
Model
IQXT-210-4
Model Issue number
3
Frequency Parameters
Frequency
10.0MHz
Frequency Tolerance
Tolerance Condition
Frequency Stability
±0.50ppm
@ 25°C, 3.3V & VC=1.5V
±0.14ppm
Operating Temperature Range
Ageing
-40.00 to 85.00°C
±0.02ppm max per day, ±1ppm
max per year
Frequency Tolerance (measurement referenced to frequency
observed with TA=25°C, Vs=3.3V, VC=1.5V and within 30
days after ex-works)
Frequency Stability: TA varied across the operating
temperature range, measurement referenced to frequency
observed with TA=25°C, Vs=3.3V, VC=1.5V, load=10kΩ//10pF
and temperature variable speed less than 2°C per minute.
Ageing: TA=25°C, Vs=3.3V, VC=1.5V and after 1hr of
operation.
Supply Voltage Variation (measurement referenced to
frequency observed with TA=25°C, Vs varied from 3.13V to
3.47V, VC=1.5V and load=10kΩ//10pF): ±0.1ppm max
Load Variation (5% load change measurement referenced to
frequency observed with TA=25°C, Vs=3.3V, VC=1.5V and
Short Term Stability (@ 25°C after 10mins power on): 5E-10/s
typ @ 10MHz
Outline (mm)
Electrical Parameters
3.3V ±5%
Supply Voltage
Current Draw
10.000mA
Current: TA=25°C, Vs=3.3V, VC=1.5V and load=10kΩ//10pF
Recommended Solder Pad Layout
Frequency Adjustment
Pulling
±10ppm to ±15ppm
Control Voltage
1.5V ±1.5V
Linearity: ±10% max
Slope: Positive
Input Impedance: 100kΩ min
Output Details
Output Compatibility
Drive Capability
Output Levels: 0.8V pk-pk min
Clipped Sine
10kΩ//10pF
Noise Parameters
Phase Noise (@ 10MHz typ):
-90dBc/Hz @ 10Hz
-115dBc/Hz @ 100Hz
-135dBc/Hz @ 1kHz
-145dBc/Hz @ 10kHz
-148dBc/Hz @ 100kHz
-150dBc/Hz @ 1MHz
Sales Office Contact Details:
UK: +44 (0)1460 270200
France: 0800 901 383
Germany: 0800 1808 443
USA: +1.760.318.2824
Printed on 4 Aug 21 16:44 using Part Data Sheet V1.0018
Email: info@iqdfrequencyproducts.com
Web: www.iqdfrequencyproducts.com
Page 1 of 2
Customer Part:
Environmental Parameters
Storage Temperature Range: -55 to 105°C
ESD Level:
HBM, Class 2: 2000V to 4000V, JEDEC JS-001-2010
Machine Model, Class B: 200V to 400V, JEDEC JS-001-2010
Shock: IEC 60068-2-27, Test Ea: 100G acceleration for 6ms,
half sinewave, in 3 mutually perpendicular planes
Vibration: IEC 60068-2-6, Test Fc: 10Hz-2000Hz, 0.75mm
amplitude, 10G acceleration, 30mins per cycle, in 3 mutually
perpendicular planes, test duration 2hrs
Manufacturing Details
Moisture Sensitivity Level: 2
Maximum Reflow Temperature: 260°C (30secs max)
Compliance
RoHS Status (2015/863/EU)
REACh Status
MSL Rating (JDEC-STD-033):
Compliant
Compliant
2
Packaging Details
Pack Style: Bulk
Pack Size: 1
Loose in bulk pack
Alternative packing option available
Page 2 of 2
很抱歉,暂时无法提供与“LFTVXO063789BULK”相匹配的价格&库存,您可以联系我们找货
