OYLTDLJANF-27.000000
    TAITIEN(泰艺)
    SMD-4
    有源晶振 27MHz 1.2V SMD-4
OYLTDLJANF-27.000000 数据手册
OY Type Ultra Low Power 2.5 x 2.0mm SMD CMOS Output Crystal Oscillator Actual Size FEATURE - Ultra Low Power Supply Voltage: 0.9V, 1.2V, 1.5V Supply Options - Singled-end Output: CMOS - Frequency Support from 1MHz to 50MHz - Low Noise Typical: 0.3ps at 12kHz to 20MHz Frequency Offsets - Temperature Range: -40 to 85oC Operation - Pb-free/RoHS Compliant TYPICAL APPLICATION - loT - Game Console - Smartphone - Wearable Device - Digital Camera - Digital Consumer Electronics OY_PY DIMENSION (mm) SOLDER PAD L AYOUT (mm) 0.1 μF [ B O T T O M V IE W ] 1.625 ± 0.10 #1 #1 0.675 ± 0.10 0.675 Pin# 0.81 ± 0.15 0.29 #4 #2 #2 [ S ID E V IE W ] 1 2 3 4 0.80 #3 0.57 ± 0.10 1.225 ± 0.10 #3 2.00 ± 0.20 2.50 ± 0.20 1.225 [ TO P VIEW ] #4 RoHS Compliant 1.625 Function 0.90 Tri-state GND Output VDD Might cause malfunction if do not To ensure optimal oscillator place a by-pass capacitor of 0.1μF followperformance, the recommendation. as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 0.9V Parameter Supply Voltage Variation (VDD) Current No Load Condition, 10MHz Fo < 20MHz No Load Condition, 20MHz Fo < 50MHz Max. Min. Max. VDD+5% VDD-5% VDD+5% V 1 50 1 50 1 50 MHz - 1.5 - 2 - 3 mA - 0.9 - 1 - 1.2 mA - 1 - 1.2 - 1.2 mA Fo < 10MHz - 1.2 - 1.5 - 1.5 mA 45 55 45 55 45 55 % Output High 2.97 - 2.25 - 1.62 - V Output Low - 0.33 - 0.25 - 0.18 V 1MHz - 4 - 3 - 3 nSec Duty Cycle Output Level Transition Time: Rise / Fall Time+ Fo < 10MHz 10MHz Fo < 20MHz - 3 - 3 - 3 nSec 20MHz Fo < 50MHz - 2 - 2 - 2 nSec Startup Time Enable (High Voltage or Tri-State Floating) (Input to Pin 1) Unit Min. VDD-5% At 15pF Load No Load Condition, 1MHz 1.5V Max. VDD+5% Frequency Range Supply 1.2V Min. VDD-5% - 4 - 4 - 4 mSec 0.7xVDD - 0.7xVDD - 0.7xVDD - V - 0.3xVDD - 0.3xVDD - 0.3xVDD Disable (Low Voltage or GND) Output Loading 15 15 15 Stand by Current - 100 - 100 - 100 Aging (@ 25oC, 1st Year) - 3 - 3 - 3 Storage Temp. Range Phase Noise V pF -55 +125 -55 +125 -55 +125 Typ. Max. Typ. Max. Typ. Max. - A ppm o C 1kHz offset -130 - -133 - -135 At VDD=1.2V, 10kHz offset -140 - -143 - -143 - Fout=24MHz 100kHz offset -148 - -150 - -150 - 1MHz offset -152 - -155 - -155 - Period Jitter (Pk-Pk) - 40 - 40 - 40 pSec RMS Phase Jitter (Integrated 12kHz to 20MHz) - 1 - 1 - 1 pSec dBc/Hz Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position +Transition times are measured between 10% and 90% of VDD,withan output load of 15pF FREQ. STABILITY vs. TEMP. RANGE ppm Temp.( oC) -10~+60 -20~+70 -40~+85 25 50 * O: Available △:Conditional X: Not available *Inclusive of calibration @ 25℃, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration load variation Note: not all combination of options are available. Other specifications may be available upon request. Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(2)08/2019 31
OYLTDLJANF-27.000000 价格&库存
很抱歉,暂时无法提供与“OYLTDLJANF-27.000000”相匹配的价格&库存,您可以联系我们找货
