SXO53L3B171-106.250M 数据手册
Ceramic SMT 6 Pad LVDS Oscillator
SXO53L Series
5.0mm x 3.2mm
Features
Applications
• ±20ppm (Frequency Stability) Available
• Fiber Channel
• Ceramic Package
• Gigabit Ethernet
• LVDS
• PCI Express
• Tape and Reel
Part Numbering Guide
SXO 53 L 3 A 48 1 - 100.000M
SUNTSU OSC
FREQUENCY
MHz
TRI-STATE
(ENABLE/DISABLE)
1 : Pin 1
2 : Pin 2
5.0mm x 3.2mm
LVDS
SUPPLY VOLTAGE
2 : 2.5V±5%
3 : 3.3V±5%
CO M P L I A N T
FREQUENCY STABILITY
A : ±50ppm
B : ±30ppm
C : ±25ppm
*D : ±20ppm
Cage Code : 4GUT4
To customize your parameters, contact a Suntsu representative.
* For Frequency stability option D, contact a Suntsu representative.
Electrical Parameters
Typical
OPERATING TEMPERATURE
RANGE
07 : 0°C - +70°C
16 : -10°C - +60°C
17 : -10°C - +70°C
27 : -20°C - +70°C
38 : -30°C - +85°C
48 : -40°C - +85°C
Units
Minimum
Frequency Range
MHz
80
Maximum
170
Frequency Stability (Includes Initial
Tolerance at 25°C, Frequency Stability
over Operating Temperature, Output Load
Change, Supply Voltage Change, and First
Year Aging at 25°C.)
ppm
-20
+20
See part numbering guide for options
°C
-40
+85
Storage Temperature
°C
-55
+125
Supply Voltage (VDD) - 2.5V Option
V
2.375
2.5
2.625
Supply Voltage (VDD) - 3.3V Option
V
3.135
3.3
3.465
Current (IDD) - 2.5V Option
mA
Current (IDD) - 3.3V Option
mA
60
Output Load (LVDS)
Ω
100
Output Logic Levels High (VOH)
V
Output Logic Levels Low (VOL)
V
0.9
1.1
Differential Output Voltage (VOD)
mV
247
330
454
Differential Output Error (DVOD)
mV
1.125
1.250
1.375
0.4
0.8
50
55
Offset Voltage (VOS)
V
50
1.43
mV
Rise (TR) and Fall (TF) Time
ns
Symmetry (Duty Cycle)
45
Tri-State Input Voltage - Enable
V
0.7*VDD
Tri-State Input Voltage - Disable
V
Start-Up Time
ms
ps
www.suntsu.com
Specifications are subject
to change without notice.
1.6
50
Offset Error (DVOS)
Phase Jitter (12kHz ~ 20MHz)
Remarks
50
No Connection
0.3*VDD
10
0.4
1
Suntsu Electronics, Inc.
142 TECHNOLOGY DR., SUITE 150
IRVINE, CA 92618
Call: +1-949-783-7300 | Fax: +1-949-783-7301
SXO53L Series
5.0mm x 3.2mm
Outline Drawing & Land Pattern
All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale.
Test Circuit (LVDS)
Waveform (LVDS)
Typical Phase Noise Performance (Measured By Agilent E5052A)
Frequency - 100.000MHz
www.suntsu.com
Frequency - 125.000MHz
IRVINE, CA 92618
SXO53L Series
5.0mm x 3.2mm
Typical Jitter Performance (Measured By Agilent E5052A)
Reflow Profile
Part Marking
Tp (Time At 260°C. 20-40 Sec)
260
Rup (Ramp Up, 3°C/Sec Max)
217
Temperature (°C)
200
TI (Time Above 217°C.
60-150Sec)
150
Rdn (Ramp Down,
6°C/Sec Max)
Ts (Preheat Time.
60-180Sec)
T 25°C to Peak (480Sec Max)
Time (sec)
Tape And Reel Dimensions
1,000pcs/Reel
www.suntsu.com
IRVINE, CA 92618
SXO53L Series
5.0mm x 3.2mm
Environmental Specifications
Mechanical Specifications
Temperature Cycling
MIL-STD-883, Method 1010, Condition B
Mechanical Shock
MIL-STD-202, Method 213, Condition B
Fine Leak Test
MIL-STD-883, Method 1014, Condition A
Vibration
MIL-STD-883, Method 2007, Condition A
Gross Leak Test
MIL-STD-883, Method 1014, Condition C
Moisture Resistance
MIL-STD-883, Method 1004
Solderability
MIL-STD-883, Method 2003
Resistance to Solvents
MIL-STD-202, Method 215
Moisture Sensitivity
J-STD-020, MSL 1
Resistance to Soldering Heat
MIL-STD-202, Method 210, Condition K
www.suntsu.com
IRVINE, CA 92618
SXO53L3B171-106.250M 价格&库存
很抱歉,暂时无法提供与“SXO53L3B171-106.250M”相匹配的价格&库存,您可以联系我们找货
