YR32K76800S001
YR32K76800S001
    NEXTGEN
    SMD-2
    无源晶振 12.5pF 70KΩ ±20ppm -40℃~+85℃ SMD-2 32.768KHz
YR32K76800S001 数据手册
PART CODE: YR32K76800S001 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0623- YR32K76800S001 DATE June 23, 2021 REVISION A1 DESCRIPITION KHz SMD Crystals, L3.2*W1.5*H0.9mm, 2 Pads, CCMM series 32.76800KHz, +/-20ppm, CL 12.5pF Operating Temp. Range -40°C ~+85°C, ESR 70 Kohm Max, Reflow Profile Condition 260 °C Max. Tape/Reel, 3000pcs/Reel, RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS CCMM 32K768A20-12.5-40-70T LF PART CODE YR32K76800S001 VENDOR APPROVE Issued/Checked/Approved DATE: June 23, 2021 CUSTOMER APPROVE DATE: 1 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YR32K76800S001 KHZ SMD CRYSTALS SMD CRYSTAL CCMM 2520 SERIES TYPE 3215 4 PADS TYPE MAIN FEATURE • SMD Package, CCMM Series, L3.2*W1.5*H0.9mm, 2 Pads • Industry standard • Reflow Profile Condition 260 °C Max. • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • Small communications devices and more RFQ PART CODE GUIDE Request For Quotation YR 32K76800 S 001 1 2 3 4 1) YR: Part family Code for KHz SMD crystal L3.2*W1.5*H0.9mm, 2 Pads, CCMM series 2) 32K76800: Frequency range code for 32.76800KHz 3) S: SMD type, Package Tape/Reel, 3000pcs/Reel 4) 001: Specification code for original part No.: TGS CCMM 32K768A20-12.5-40-70T LF 2 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YR32K76800S001 KHZ SMD CRYSTALS CCMM SERIES 3215 TYPE DIMENSION (Unit: mm) Image for reference Marking Frequency Range CCMM or Marking Internal Control Code Land Pattern for reference 3 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YR32K76800S001 KHZ SMD CRYSTALS CCMM SERIES 3215 TYPE PRODUCT STRUCTURE Item No. Component Name Material Name 1 Crystal Case Ceramic (A1203) 2 Crystal Cover/Lid KV (Fe/Co/Ni) 3 Crystal Chip/Blank SiO2 4 Electrode Au, Ag 5 Adhesive Resin, Ag EQUIVALENT CIRCUIT NOTES BEFORE USE Ultrasonic Cleaning: General cleaning solutions or ultrasonic cleaning method may be used to clean our products. However, under certain circumstances, ultrasonic cleaning machine could generate resonance at the oscillation frequency of our products and thus deteriorate the electrical characteristics in device and even damage the overall structure of device. Therefore, verification test is recommended before cleaning. Ultrasonic Welding Avoid mounting and processing by Ultrasonic welding this method has a possibility of an excessive vibration spreading inside the crystal products and become the cause of characteristic deterioration and not oscillating. Storage Temperature Description Storage Temperature is only for the product itself, the temperature for the packing material is 5~40°C Recommended Conditions for Manual Welding Max. Temperature: 350±10°C, Time: 3 sec Max., Re-solder time: twice Max. 4 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YR32K76800S001 KHZ SMD CRYSTALS CCMM SERIES 3215 TYPE ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Original Manufacturer Typical Condition Max. TGS TGS Crystals Holder Type CCMM KHz SMD Crystal L3.2*W1.5*H0.9mm, 2 Pads Frequency Range 32K768 KHz Mode of Oscillation A Frequency Tolerance 20 ppm -12.5 pF Load Capacitance Frequency/Temp Coefficient Operation Temperance Storage Temperance Equivalent Series Resistance (ESR) AT Fundamental ppm/°C² -40 -70 32.76800 -20 +20 12.5 -0.02 - 0.04 °C -40 +85 °C -55 +125 KΩ 70 Drive Level μW 0.5 Shunt Capacitance (C0) pF Dynamic Capacitance (C1) fF Turnover Temp °C 1.1 +20 +25 +30 60000 Capacitance Ratio 450 Aging ppm/year Insulation Resistance MΩ ±3 500 T Tape/Reel, 3000pcs/Reel RoHS Status LF RoHS III compliant Add Value @1st year @100VDC ± 15VDC Package Special Code* 2.0 4.1 Quality Factor Other @25°C N/A 2 letter or digits; Blank: N/A Note: 1) Original Part Number: TGS CCMM 32K768A20-12.5-40-70T LF 2) * Internal Control Code- 2 letter or digits; Blank: N/A 5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YR32K76800S001 KHZ SMD CRYSTALS CCMM SERIES 3215 TYPE RELIABILITY Test Items Test Method And Conditions Test Standard High Temperature High Humidity Storage Temperature: 60℃ ± 2 ℃ Relative Humidity: 90%~95% RH For Time: 500 ± 12 Hours A, C, D, G High Temperature Storage Temperature: 125℃ ± 2℃ Time: 1000±12 Hours. B, C, G Low Temperature Storage Temperature: -40℃ ± 2℃ Time: 500 ± 12 Hours. A, C, G Temperature Cycle The crystal unit shall be subjected to 100 successive change of temperature cycles. A, C, G Solderability The solder pot temperature is 260±5℃ , dwell time 2±0.6sec F Drop Test Height: 180 cm; Dropped Cycle: 3 cycles; Drop it on to a concrete board for 6 Directions (X,Y,Z), that should be 1 cycle B, C Vibration Frequency Range: 10Hz~55Hz Amplitude: 1.5mm±15%; Sweep time: 2~3 Minutes, 2 Hours in each direction, total 6 Hours A, C Leakage Test Helium Bombing 5.0 ~5.5 Kgf/cm²; for 2 hours E 6 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: YR32K76800S001 KHZ SMD CRYSTALS CCMM SERIES 3215 TYPE RELIABILITY Test Items Test Method And Conditions Test Standard Terminal Strength Shall be pressurized at a speed of approx. 0.5mm/sec. in the direction indicated by the arrow unit the bending width reaches 3mm and held for 5 sec. B, C Sticking Tendency A R0.5 Jig shall be used to apply a 10N dead load in the direction indicated by the arrow to the element and retain it for 10 sec. B, C Element Assembly Strength A R0.5 Jig shall be used to apply a 10N dead load in the direction indicated by the arrow to the element and retain it for 10 sec. B, C Test Standard Symbol Specification Value A Frequency Change permitted ∆F≤10ppm B Frequency Change permitted ∆F≤20ppm C Equivalent Series Resistance Change Permitted ∆CI≤5KΩ or 20% D Insulation Resistance >500 MΩ E Leak Rate Less than
YR32K76800S001 价格&库存
很抱歉,暂时无法提供与“YR32K76800S001”相匹配的价格&库存,您可以联系我们找货
