12.87159
12.87159
    GEYER
    SMD3215_2P
    无源晶振 32.768kHz ±20ppm 12.5pF 50kΩ -40℃~+85℃
12.87159 数据手册
Tuning Fork Crystal SMD-version model KX–327NHT frequency operating temperature frequency tolerance at +25°C temperature tolerance (parabolic coefficient) at -40° ~ +85°C 32.768 kHz -40° ~ +85°C ± 20 ppm -0.035 ppm/°C2 typ. turnover temperature +25°C ± 5°C storage temperature range load capacitance CL -55°C ~ +125°C 12.5 pF motional capacitance (C1) series resonance R1 max. aging at +25°C (first year) max. shunt capacitance Co 0,0036 pF, typ. 50k Ohm ± 3 ppm max. 1.3 pF (1,0 pF typ.) 1.0 µW max., 0.1µW typ 20000 min. 3000 pcs. 12.87159 drive level quality factor (Q) contents of reel part no. Remarks: ● Recommended for Intel 8/C220-series, PCH–LP, Chipset Dimensions (mm): Reflow soldering condition: Tape specification: Suggested soldering pad: reel diameter 180 mm GEYER ELECTRONIC e.K. Lochhamer Schlag 5 82166 Gräfelfing/München Tel. +49 89 546868-0 quartz@geyer-electronic.de www.geyer-electronic.de Version 03.11.2014
12.87159
物料型号:KX-327NHT 器件简介:GEYER石英技术制造的音叉晶体振荡器,SMD版本。 引脚分配:文档中未提供引脚分配信息。 参数特性: - 频率:32.768 kHz - 工作温度范围:-40°C至+85°C - 25°C时的频率容差:±20 ppm - -40°C至+85°C时的温度容差(抛物线系数):典型值-0.035 ppm/°C² - 转折温度:+25°C±5°C - 存储温度范围:-55°C至+125°C - 负载电容CL:12.5pF - 动态电容(C1):典型值0.0036 pF - 串联谐振电阻R1最大值:50k Ohm - +25°C下的第一年老化:最大±3 ppm - 并联电容Co:1.3 pF(典型值1.0pF) - 驱动电平:最大1.0 W,典型值0.1 W - 品质因数(Q):最小20000 功能详解:文档中未提供功能详解应用信息:推荐用于Intel 8/C220系列,PCH-LP芯片组。 封装信息:尺寸(mm)和回流焊接条件在文档中有详细描述,但未提供封装类型信息。
12.87159 价格&库存
很抱歉,暂时无法提供与“12.87159”相匹配的价格&库存,您可以联系我们找货
  • 1+6.344621+0.82078
  • 10+5.5374110+0.71635
  • 25+5.2343625+0.67715
  • 50+5.0174750+0.64909
  • 100+4.81029100+0.62229
  • 250+4.54914250+0.58850
  • 500+4.36096500+0.56416
  • 1000+4.180541000+0.54082
库存:6450
12.87159
    • 1+8.49960
    • 200+3.39120
    • 500+3.28320
    • 1000+3.22920
    • 3000+3.909973000+0.50582
    • 6000+3.748396000+0.48491
    • 9000+3.657069000+0.47310
    • 15000+3.5452015000+0.45863
    • 21000+3.4734421000+0.44935
    库存:6450
