LFXTAL026900REEL
LFXTAL026900REEL
    IQD
    HC-49S/SMD
    无源晶振 6MHz ±20ppm 16pF 60Ω -10℃~+60℃
LFXTAL026900REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL026900Reel Customer Part: Description Industry standard SMD crystal Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Lead wires are mounted onto a plastic former to create a gull wing mount Model HC49/4HSMX Model Issue number 17 Frequency Parameters Frequency 6.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±20.00ppm @ 25°C ±2°C ±50.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±5ppm typ per year @ 25°C Outline (mm) Electrical Parameters 16.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 60.00Ω max Environmental Parameters Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Storage Temperature Range: -55 to 125°C RoHS Terminations RoHS Reflow Temp 260°C max for 10s max Typical Frequency vs Temperature Curves Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 2 Sep 21 12:33 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL026900REEL
1. 物料型号:LFXTAL026900Reel 2. 器件简介:行业标准SMD晶体,采用惰性气氛下电阻焊接,玻璃与金属密封引线,HC49/4HSMX型号,引线安装在塑料基座上,形成海鸥翼安装。 3. 引脚分配:文档中未明确提供引脚分配信息。 4. 参数特性: - 频率:6.0MHz - 频率容差:±20.00ppm - 环境容差:±50.00ppm - 频率稳定性:在-10.00至60.00°C的工作温度范围内 - 基频:基础 - 老化:25°C时典型每年±5ppm - 电气参数:负载电容(CL)7pF最大,寄生电容(C0)16.00pF,驱动水平500µW最大,ESR 60.00Ω最大 5. 功能详解:文档中未提供详细的功能解释。 6. 应用信息:文档中未明确提供应用信息。 7. 封装信息:符合RoHS指令2015/863/EU,符合REACH法规,MSL等级不适用,包装细节包括卷轴包装,符合EIA-481-D标准,包装大小为1,000。
LFXTAL026900REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL026900REEL”相匹配的价格&库存,您可以联系我们找货
