LFXTAL003102BULK
LFXTAL003102BULK
    IQD
    HC49S
    无源晶振 4.433619MHz ±30ppm 20pF 130Ω -10℃~+60℃
LFXTAL003102BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL003102Bulk Customer Part: Description Industry standard leaded package Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Model HC49/4H Model Issue number 15 Frequency Parameters Frequency 4.433619MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±50.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±5ppm typical per year at 25°C Outline (mm) Electrical Parameters 20.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 130.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Typical Frequency vs Temperature Curves Packaging Details Pack Style: Bulk Pack Size: 100 Loose in Bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 15 Dec 21 0:51 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL003102BULK
- 物料型号:LFXTAL003102 - 封装类型:工业标准引线封装,采用惰性气体中电阻焊接,玻璃对金属密封引线。 - 频率参数: - 频率:4.433619MHz - 频率容差:25°C时为±30.00ppm,温度范围-10.00到60.00°C时为±50.00ppm - 频率稳定性:基频情况下,每年在25°C时典型值±5ppm - 电气参数: - 负载电容(CL):20.00pF,最大偏差7pF - 并联电容(C0):未提供具体数值 - 驱动电平:未提供具体数值 - 等效串联电阻(ESR):未提供具体数值 - 环境参数: - 存储温度范围:-55 to 125°C - 冲击:981m/s²,6ms,每个相互垂直的平面上3次 - 振动:10Hz-60Hz,振幅0.75mm;60Hz-500Hz,98.1m/s²,30分钟,每个相互垂直的平面上 - 符合性: - RoHS状态:符合2015/863/EU - REACh状态:符合 - MSL等级:未适用 - 封装信息: - 包装风格:散装 - 包装尺寸:100 - 包装视图:未提供具体视图 - 温度频率曲线图:提供了典型频率与温度的关系曲线图 - 销售办公室联系方式: - 提供了英国、德国、法国和美国的联系电话和电子邮件信息
LFXTAL003102BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL003102BULK”相匹配的价格&库存,您可以联系我们找货
