LFXTAL003118BULK
LFXTAL003118BULK
    IQD
    HC-49U
    无源晶振 5MHz ±20ppm 30pF 100Ω -10℃~+60℃
LFXTAL003118BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL003118Bulk Customer Part: Description Industry standard leaded package Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Standard 2 leg HC49 package Model Model Issue number HC49 15 Frequency Parameters Frequency 5.0MHz Frequency Tolerance Frequency Stability ±20.00ppm ±50.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±3ppm typical per year Outline (mm) Electrical Parameters 30.00pF 7pF max Load Capacitance Shunt Capacitance Drive Level ESR 1mW max 100.00Ω max Environmental Parameters Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Storage Temperature Range: -55 to 125°C Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Bulk Pack Size: 100 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 12 Dec 21 10:03 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL003118BULK
1. 物料型号:LFXTAL003118,采用标准2腿HC49封装,散装销售。 2. 器件简介:该器件为电阻焊接、在惰性气氛中密封的玻璃至金属密封产品,符合RoHS和REACH标准。 3. 引脚分配:文档中未明确提供引脚分配信息,但根据HC49封装的通用标准,通常有两个引脚。 4. 参数特性: - 频率:5.0MHz - 频率容差:56.4ppm至4.88ppm - 温度范围:-10.00至60.00°C,频率稳定性为±50.00ppm - 老化:典型每年±3ppm 5. 功能详解:文档中未提供详细的功能解释,但通常此类晶振用于为电子设备提供稳定的时钟信号。 6. 应用信息:文档中未明确提供应用信息,但根据其参数特性,可能用于需要精确时钟信号的电子设备。 7. 封装信息:HC49封装,散装销售,包装风格为散装,每包100个。
LFXTAL003118BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL003118BULK”相匹配的价格&库存,您可以联系我们找货
LFXTAL003118BULK
