RoHS Compliant
Pb - Lead Free
Ltr
Revisions
Date
Electrical Specifications:
Frequency Range
Mode of Oscillation
Fundamental
Standard
Frequency Tolerance at 25°C
Optional
Standard
Frequency Stability over
Temperature Range
Optional
Operating Temperature Range
Standard
Extended
Storage Temperature Range
Aging per Year
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
12.000 to 60.000
12.000 to 60.000
±30
±25
±20
±15
±10
±50
±30
±25
±20
±15
±10*
-10 to +70
-40 to +85
-55 to +125
±3
7 to 32 and Series Resonance
3.0
See ESR Table
100
500 at at 100 Vdc ± 15 Vdc
MHz
PPM Max
(Note 1)
PPM Max
(Note 1)
ºC
PPM Max
pF
Ohms
uW Typ
M Ohms
Frequency Range and ESR Values:
Frequency Range in MHz
12.000
14.000
16.000
20.000
24.000
25.000
45.000
to
to
to
to
to
to
to
ESR Ohm Max
Mode of Operation
200
150
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
13.999
15.999
19.999
23.999
24.999
44.999
60.000
90
70
60
50
40
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: May 1, 2013
Microprocessor Crystal Unit
Low Profile
2.5 x 2.0 millimeter Surface Mount
General Product Specification
Part Number:
C2E Series
www.aker-usa.com
Appr
Mechanical Outline:
2.5 ± 0.15
2.0 ± 0.15
#4
Ceramic Base
Metal Lid
#3
AKER
#1
#2
0.65 Max.
0.9
1.65
#4
#3
0.575
0.9
#2
0.65
#1
1.225
1.0
0.7
#2:GND #4:GND
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: May 1, 2013
P/N:
www.aker-usa.com
C2E Series
1.5
2.0
1.75
Carrier Tape Dimensions:
4.0
B-B SECTION
AKER
AKER
AKER
AKER
AKER
AKER
AKER
AKER
A
3.4
Pin #1
A
8.0
3.5
B
B
1.0
4.0
1.4
2.7
Dimensions
millimeters.
A-Aare
SECTION
Solder Reflow Characteristics:
Page:
3/4
Date: May 1, 2013
P/N:
www.aker-usa.com
C2E Series
How to build a Part Number:
Series
Package
C
2E
Frequency
12.000 to 60.000
Load Capacitance
Standard
Frequency Tolerance
(Note 1)
Optional
Standard
Frequency Stability
(Note 1)
Optional
Standard
Temperature Range
Extended
Packaging
7
10
12
16
18
S
30
25
10
50
30
25
10
See Notes
X
M
R
R3
Parameter
2.5 x 2.0 mm
MHz
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
±30 PPM
±25 PPM
±20 PPM
± 15 PPM
±10 PPM
±50 PPM
±30 PPM
±25 PPM
±20 PPM
±15 PPM
±10 PPM*
-10 to +70 ºC
-40 to +85 ºC
250pcs Reel
1000pcs Reel
3000pcs Reel
Part Number Example:
C2E-50.000-18-3050-R
C2E- 2.0 x 2.5 mm SMD Seam Seal Crystal Unit
50.000 MHz Nominal Frequency
18 pF Load Capacitance
3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability
Fundamental Mode
-10 to +70° C Temperature Range
R: Tape and Reel Packaging
Notes:
1- Frequency Tolerance and Stability options are limited due to physical size.
* ±10 PPM Temperature Stability is only available from -30 to +85° C.
2- Standard Temperature Range does not need to be included in Part Number description.
3- Product is shipped in Tape and Reel configuration.
4- Quantities less than 250pcs are shipped in tape.
5- Specification subject to change without notice.
Page:
4/4
Date: May 1, 2013
P/N:
www.aker-usa.com
C2E Series
C2E-27.120-8-1520-M 价格&库存
很抱歉,暂时无法提供与“C2E-27.120-8-1520-M”相匹配的价格&库存,您可以联系我们找货
