TSM22-H50CQ33ST-12.000M
    TRANSKO
    SMD2520_4P
    有源晶振 12.000000MHz 3.3V -40℃~+85℃ HCMOS
TSM22-H50CQ33ST-12.000M 数据手册
TSM22 RoHS Compliant ULTRA MINIATURE SMD CMOS OSCILLATOR (2.5 x 2.0 x 1.0mm) FEATURES: • WIDE FREQUENCY RANGE LOW VOLTAGE / LOW CURRENT • • AEC-Q200 QUALIFIED OPTION ■ SPECIFICATION FREQUENCY RANGE FREQUENCY STABILITY OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE RANGE SUPPLY VOLTAGE ±10% 25KHz ~ 156.250MHz ±10ppm ~ ±100ppm STD: -10°C ~ 70°C, Option: -40°C ~ 85°C (See P/N guide for other options) -55°C ~ 125°C 1.0VDC ~ 5.0VDC (See P/N guide for other options) SUPPLY CURRENT 15mA max. LOGIC FAMILY LOAD LEVEL LOGIC ‘1’ (VOH) OUTPUT LEVEL LOGIC ‘0’ (VOL) SYMMETRY(DUTY CYCLE) RISE AND FALL TIME (Tr/Tf) START-UP TIME ENABLE (VIH) STAND-BY VOLTAGE DISABLE (VIL) ENABLE DELAY TIME DISABLE DELAY TIME AGING @ 25°C ± 3°C PHASE JITTER RMS (12kHz ~ 20MHz) HCMOS 15pF 0.9 x VDD min. 0.1 x VDD max. STD: 40% / 60% @ 1/2VDD level, Option: 45% / 55% 3.0nS typ., 10nS max. 10mS max. 0.7 x VDD ≤ VIH ≤ VDD or N/C VIL ≤ 0.3 x VDD 10mS max. 150nS max. ±3.0ppm / 1st year max. 1.0pS max. ■ PACKAGE DIMENSIONS 4 ■ SOLDER PATTERN ■ REFLOW PROFILE 1.70 3 Soldering 255 ±5°C 0.85 2.00±0.1 Top 1.35 Marking Pre-heating 1.0 Unit :mm * 1 170 ±5°C 150 ±5°C 2
TSM22-H50CQ33ST-12.000M 价格&库存
很抱歉,暂时无法提供与“TSM22-H50CQ33ST-12.000M”相匹配的价格&库存,您可以联系我们找货
    • 1+33.02640
    • 200+13.18680
    • 500+12.74400
    • 1000+12.52800
