S218025T-27.000-X-R
S218025T-27.000-X-R
    AKER(安碁科技)
    SMD2520_4P
    有源晶振 27.000000MHz 1.8V -40℃~+85℃ HCMOS
S218025T-27.000-X-R 数据手册
Revisions Ltr Date Appr RoHS Compliant Pb - Lead Free Electrical Specifications: Frequency Range 2.000 ~ 125.000 MHz Frequency Stability ±20 ~ ±100 ppm ±3 ppm Max. Aging per Year Operating Temperature Range Standard -10 ~ +70 Extended -40 ~ +85 -55 ~ +125 Storage Temperature Range 1.8 ± 5% 2.5 ± 5% 3.3 ± 10% 1.62 ~ 3.63 2.000 to 9.999MHz 3 6 7 7 10.000 to 19.999MHz 5 8 7 7 20.000 to 31.999MHz 5 8 12 12 32.000 to 50.000MHz 10 20 20 20 50.001 to 125.000MHz 15 25 30 30 Supply Voltage Input Current Output Voltage VDD mA Max. Logic High (Voh) 90% VDD Min. Logic Low (Vol) 10% VDD Max. Output Symmetry (Duty Cycle) Standard 40 ~ 60 ( at 50% VDD) Tight 45 ~ 55 ( at 50% VDD) % Output Level CMOS Output Load 15 Rise and Fall Time °C pF Max. 2.000 to 9.999MHz 5 7 6 7 10.000 to 19.999MHz 5 7 6 7 20.000 to 31.999MHz 5 6 5 6 32.000 to 50.000MHz 5 6 5 6 50.001 to 125.000MHz 7 7 6 7 ps Max. RMS 1 Phase Jitter (12 KHz to 20 MHz) ns Max. Tri-State Enable-Disable Function 10 Start Up Time ms Max. Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage change, output load change, shock, vilbration, and 1st year aging at +25°C. Specification Title: No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan All dimensions are millimeters. CAD: TCR Review: EG Appr: JL Page: 1/4 Date: July 1,2020 HCMOS Output Clock Oscillator Ultra Miniature 2.0 x 2.5 millimeter Surface Mount General Product Specification Part Number: www.aker-usa.com S2 Series Mechanical Outline and Solder Pad Layout: 2.5 ± 0.15 2.0 ± 0.15 #4 Ceramic Base Metal Lid #3 AKER #1 #2 0.95 Max. 0.95 1.625 #4 #3 0.575 0.9 #2 0.65 #1 1.225 1.0 0.675 Pin Connection PIN No. #1 Enable/Disable Function PIN #1 Connection Enable/Disable #2 GND #3 Output #4 VDD PIN #3 HIGH or OPEN Operating LOW High Impedance Package is Seam Sealed Ceramic-Metal. Terminator Pads are Ni/Au. Dimensions are millimeters. Page: 2/4 Date : July 1,2020 www.aker-usa.com P/N: S2 Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION AKER AKER AKER AKER AKER AKER AKER AKER A 2.75 Pin #1 A 8.0 3.5 B B 1.0 4.0 0.8 2.25 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date : July 1,2020 www.aker-usa.com P/N: S2 Series How to build a Part Number: Series Package S 2 Parameter 2.0 x 2.5 mm Supply Voltage 33 25 18 M +3.3 VDD ± 10% +2.5 VDD ± 5% +1.8 VDD ± 5% +1.62 ~ +3.63 VDD Temperature Stability 10 05 025 ±100 ppm ±50 ppm ±25 ppm See Notes T 40%~60% 45%~55% Duty Cycle Frequency 2.000~125.000 MHz - Temperature Range See Notes X -10 ~ +70 °C -40 ~ +85 °C - Packaging M R R3 250pcs Reel 1000pcs Reel 3000pcs Reel Part Number Example: S23305T-50.000-X-R S2: 2.0 x 2.5 mm SMD Package 33: +3.3±10% VDD Supply Voltage 05: ±50 ppm Temperature Stability T: 45%~55% Tight Symmetry 50.000 MHz Nominal Frequency X: -40 ~ + 85°C Extended Temperature Range R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 250pcs are shipped in tape only. 4- Specification subject to change without notice. Page: 4/4 Date : July 1,2020 www.aker-usa.com P/N: S2 Series
S218025T-27.000-X-R
1. 物料型号:S2系列。 2. 器件简介:HCMOS输出时钟振荡器,超小型2.0 x 2.5毫米表面贴装。 3. 引脚分配: - #1:使能/禁用 - #2:地(GND) - #3:输出 - #4:电源电压(VDD) 4. 参数特性: - 频率范围:2.000~125.000 MHz - 频率稳定性:+20~±100 ppm最大 - 年老化:±3 ppm - 工作温度范围:标准 -10~+70°C,扩展 -40~+85°C - 存储温度范围:-55~+125°C - 电源电压:1.8±5%、2.5±5%、3.3±10%、1.62~3.63 VDD - 输入电流:根据频率不同,最大电流从3 mA到30 mA不等 - 输出电压:逻辑高(Voh)至少90% VDD,逻辑低(Vol)最大10% VDD - 输出对称性(占空比):标准40~60%(在50% VDD时),紧凑45~55% - 输出负载:最大15 pF - 上升和下降时间:根据频率不同,最大时间从5 ns到7 ns不等 - 相位抖动(12KHz至20 MHz):最大1 ps RMS - 使能/禁用功能:三态 - 启动时间:最大10 ms 5. 功能详解:文档详细描述了振荡器的工作原理,包括使能/禁用功能,以及不同引脚的状态对振荡器工作状态的影响。 6. 应用信息:文档提供了如何构建部件编号的指南,以及封装信息,包括载体胶带尺寸和焊接再流特性。 7. 封装信息:封装为密封陶瓷金属,端子垫为Ni/Au,所有尺寸单位为毫米。
S218025T-27.000-X-R 价格&库存
很抱歉,暂时无法提供与“S218025T-27.000-X-R”相匹配的价格&库存,您可以联系我们找货
