OVETGCJANF-25.000000 数据手册
OV Type
5.0 x 3.2 mm SMD Crystal Oscillator
Actual Size
FEATURE
- Typical 5.0 x 3.2 x 1.2 mm ceramic SMD package.
- Tight symmetry (45 to 55%) available.
- Realize the standby function with Tri-State
TYPICAL APPLICATION
- GPS, Mobile Phone
- WLAN, Wireless, Fiber/10Gbit Ethernet
- Notebook, PDA, DSC
OV
DIMENSION (mm)
RoHS Compliant
SOLDER PAD L AYOUT (mm)
[ BOTTOM VIEW ]
#1
#2
#3
2.54 ± 0.15
#4
2.54
#2
1.20 ± 0.15
1.20 ± 0.10
[ SIDE VIEW ]
Pin#
1
2
3
4
1.00 ± 0.15
2.20 ± 0.15
3.20 ± 0.20
#3
#1
0.1µF
2.20
5.00 ± 0.20
#4
1.20
[ TOP VIEW ]
Function
Tri-state
GND
Output
VDD
1.50
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3V
Parameter
Min.
2.5V
Max.
Min.
1.8V
Max.
Min.
Max.
Supply Voltage Variation(VDD)
VDD -10% VDD+10% VDD -10% VDD+10% VDD -10% VDD+10%
Frequency Range
0.0137
160
0.0137
160
135
0.0137
Supply Frequency
2.048, 25, 26, 27, 50, 66.667, 100, 125
Supply Current
_
_
_
1
13.7 kHz Fo
93 kHz
1
1
_
_
_
10
0.3125 MHz Fo < 50 MHz (A1)
7
8
_
_
_
40 MHz Fo < 75 MHz
15
18
_
_
_
35
75 MHz Fo < 135 MHz
25
30
_
_
_
_
45
135 MHz Fo
40
_
_
_
2.97
2.25
1.62
Output Level (CMOS) Output High (Logic “1”)
_
_
_
Output Low (Logic “0”)
0.33
0.25
0.18
Transition Time:Rise/Fall Time
_
_
_
50
13.7 kHz Fo
93 kHz
50
50
_
_
_
5
0.3125 MHz Fo < 100 MHz
5
5
_
_
_
3
100 MHz Fo
3
3
_
_
_
5
5
5
Start Time
_
_
_
15
15
15
Output Drive Capability (CL)
Tri-State (Input to Pin 1)
_
_
_
Enable (High voltage or floating)
2.31
1.75
1.26
_
_
_
0.99
0.75
0.54
Disable (Low voltage or GND)
_
_
_
Period Jitter(Pk-Pk)
40
40
40
_
_
_
RMS Phase Jitter (Integrated 12 kHz~20 MHz)
1
1
1
_
_
_
Standby Current
10
10
10
_
_
_
Aging (@ 25°C 1st year)
±3
±3
±3
Storage Temp. Range
-55
125
-55
125
125
-55
unit
V
MHz
MHz
mA
V
nSec
mSec
pF
V
pSec
pSec
µA
ppm
°C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
+ Transition times are measured between 10% and 90% of VDD, with an output load of 15pF.
FREQ. STABILIT Y vs. TEMP. RANGE
Temp. (°C)
ppm
±20
±25
±50
-10 ~ +60
-20 ~ +70
-40 ~ +85
-40 ~ +125
○: Available △:Conditional
X: Not available
* Inclusive of calibration @ 25 °C, operating temperature range, input
voltage variation, load variation, aging (1st year), shock, and vibration
Note: not all combination of options are available. Other specifications may be available upon request.
34
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(18)04/2019
OVETGCJANF-25.000000 价格&库存
很抱歉,暂时无法提供与“OVETGCJANF-25.000000”相匹配的价格&库存,您可以联系我们找货
