CS52-32.768K-12.5
CS52-32.768K-12.5
    TRANSKO
    SMD4918_2P
    无源晶振 32.768kHz ±20ppm 12.5pF 70kΩ -40℃~+85℃
CS52-32.768K-12.5 数据手册
CS52 RoHS Compliant MINIATURE CERAMIC SMD TUNING FORK CRYSTAL (4.9 x 1.8x 1.0mm) FEATURES:  SMALL CERAMIC SMD PACKAGE TUNING FORK   EXCELLENT HEAT RESISTANCE -40°C ~ 85°C OPERATING TEMPERATURE ■ SPECIFICATION 32.768kHz FREQUENCY RANGE STD: ±20ppm, Option : ±10ppm available (Consult factory) FREQUENCY TOLERANCE @ 25ºC -0.034ppm ±0.006 ppm / ºC2 TEMPERATURE COEFFICIENT OPERATING TEMPERATURE RANGE -40°C ~ 85°C STORAGE TEMPERATURE RANGE -55°C ~ 125°C 25°C ± 5°C TURN OVER TEMPERATURE 12.5pF typ. 9.0pF available LOAD CAPACITANCE SHUNT CAPACITANCE 1.35pF typ. MOTIONAL CAPACITANCE 0.002pF typ. EQUIVALENT SERIES RESISTANCE 70k max. INSULATION RESISTANCE 500M min. @ 100VDC ± 15VDC 0.1µW typ. 1.0µW max. DRIVE LEVEL AGING @ 25°C ± 3°C ±3.0ppm/ 1st year max. QUALITY FACTOR 20000 min. SHOCK ±5.0ppm max. VIBRATION ±5.0ppm max. ■ PACKAGE DIMENSIONS ■ SOLDER PATTERN ■ REFLOW PROFILE Soldering 1.3 255 ±5°C Pre-heating 1.8 Marking 2.2 150 ±5°C 4.2 Unit :mm 4.9
CS52-32.768K-12.5 价格&库存
很抱歉,暂时无法提供与“CS52-32.768K-12.5”相匹配的价格&库存,您可以联系我们找货
CS52-32.768K-12.5
    • 1+18.86760
    • 200+7.52760
    • 500+7.27920
    • 1000+7.16040
