WTL1M60551VH
WTL1M60551VH
    WTL(维拓)
    SMD2016_4P
    无源晶振 25MHz ±10ppm 12pF
WTL1M60551VH 数据手册
Quartz Crystal, Series TX1 SMD Seam Sealed Crystals 2.0×1.6×0.5 mm Feature Size 2.0 × 1.6 , Ultra thin , thickness 0.5mm High precision and high frequency stability Excellent heat resistance and environmental characteristics Designed for automatic mounting and reflow soldering RoHS Compliant / Pb Free Electrical Specifications Item Specifications Frequency Range(MHZ) 16~19.2 Mode AT/Fundamental 19.2~30 Load Capacitance (CL) 8pF, 10pF, 12pF or Specify Frequency Tolerance( at 25°C ) ±10ppm ~ ±30ppm or specify Operating Temperature Range -20~+70°C or Specify Frequency Stability Over Operating Temperature Range ±10ppm ~ ±30ppm or specify Equivalent Series Resistance (ESR) max. 200Ω Storage Temperature Range -55~+125°C 100Ω Shunt Capacitance( C 0 ) 3pF Max Drive Level (Typical) 1 ~ 200μW (50μW typical) Aging @25°C 1st Year (Max) ±3 ppm/year 30~96 80Ω Dimension(mm) 03 http://www.wtlcrystals.com Email:wtl@wtlcrystals.com Tel:86-755-82677582
WTL1M60551VH 价格&库存
很抱歉,暂时无法提供与“WTL1M60551VH”相匹配的价格&库存,您可以联系我们找货
