CFE4-A7BP-155.52
CFE4-A7BP-155.52
    CARDINALCOMPONENTS
    SMD-4
    有源晶振 3.3V 155.52MHz SMD-4
CFE4-A7BP-155.52 数据手册
CARDINAL CARDINAL COMPONENTS COMPONENTS LVPECL Surface Mount XO * Serial Communications * Routers * Switches * WAN Interfaces * Test Equipment * LVPECL Output * Industry Standard Outline Part Numbering Example: SERIES CFE4 CFE4 Z - A5 BP - 222.5792 A5 Z CFE4 CFE4 Applications BP OPERATING TEMP. PACKAGING OPTIONS Blank = 0°C ~ +70°C Blank = Bulk A5 = -20°C ~ +70°C Z = Tape and Reel A7 = -40°C ~ +85°C 222.5792 STABILITY FREQUENCY Blank = ±100 ppm BP = ±50 ppm CFE4 Max Unit 38 640 MHz -50 + 50 ppm 3.465 V Specifications: Min Frequency Range: Stability: Supply Voltage: 3.135 Typ 3.3 Operating Temperature: -40 + 85 °C Storage Temperature: -55 + 125 °C Duty Cycle: 45 55 % 10 mS 5 ppm 100 mA Start-Up Time: 3 Aging: (ppm/1st Year) Ta=25C, Vdd=3.3V Supply Current: Short Circuit Current: ± 50 mA RMS Period Jitter: 5 pS RMS Integrated Jitter: 12kHz to 20MHz 0.7 pS -120 Phase Noise @ 10kHz: Output Voltage: Voh Vol Rise/Fall Time: Output Level: Packaging: dBc/Hz Vdd - 1.025 0.4 PIN Function 1 LVPECL2 Ground 3 LVPECL+ 4 VDD Vdd - 1.62 V V 0.8 nS LVPECL Tape and Reel 1000 pcs per Reel LVPECL Levels Test Circuit Vdd OUT 50Ω 50Ω ___ OUT Cardinal Components, Inc., 155 Rt. 46 W, Wayne, NJ. 07470 TEL: (973)785-1333 FAX: (973)785-0053 E-Mail: sales@cardinalxtal.com http://www.cardinalxtal.com  Rev.3-6/11/07 2.0 V
CFE4-A7BP-155.52 价格&库存
很抱歉,暂时无法提供与“CFE4-A7BP-155.52”相匹配的价格&库存,您可以联系我们找货
