SXT21410DB38-25.000MT
    SUNTSU
    SMD2016_4P
    无源晶振 25MHz 120Ω 10pF ±20ppm -30℃~+85℃ SMD2016_4P
SXT21410DB38-25.000MT 数据手册
Ceramic SMT 4 Pad Crystal SXT214 Series 2.0mm x 1.6mm Features Applications • ±10ppm/±10ppm (Tolerance/Stability) Available • Office Automation • Ultra-Miniature Package • Small Communication Devices • Audio/Visual Bluetooth • AT-Cut Fundamental • SSD • Tape and Reel • USB Part Numbering Guide SXT 21 4 18 A A 48 - 25.000M SUNTSU CRYSTAL FREQUENCY MHz 2.0mm x 1.6mm 4 PAD OPERATING TEMPERATURE RANGE** 07 : 0°C - +70°C LOAD CAPACITANCE FREQUENCY STABILITY 16 : -10°C - +60°C FREQUENCY TOLERANCE S : Series A : ±50ppm A : ±50ppm 17 : -10°C - +70°C COMPLIANT 8-32 : 8pF - 32pF B : ±30ppm B : ±30ppm 27 : -20°C - +70°C C : ±25ppm C : ±25ppm 38 : -30°C - +85°C D : ±20ppm D : ±20ppm 48 : -40°C - +85°C E : ±15ppm E : ±15ppm Cage Code: 4GUT4 F : ±10ppm* F : ±10ppm To customize your parameters contact a Suntsu representative. * For frequency stability option F contact a Suntsu representative. ** For operating temperatures of -55-125°C a Suntsu representative. Electrical Parameters Units Minimum Frequency Range MHz 16 60 AT-Cut Fundamental. Frequency Tolerance at +25ºC ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Op Temp ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Aging ppm -2 +2 First year @ +25ºC. Operating Temperature °C -40 +85 Storage Temperature °C -40 +125 Load Capacitance pF 8 16 Shunt Capacitance pF Drive Level µW Insulation Resistance MΩ Typical Maximum Remarks See part numbering guide for options. See part numbering guide for options. 5 50 100 500 @ 100VDC ± 15V. 16.000MHz ~ 20.999MHz Ω 200 AT-Cut Fundamental ESR - 21.000MHz ~ 25.999MHz Ω 120 AT-Cut Fundamental 26.000MHz ~ 40.999MHz Ω 100 AT-Cut Fundamental 41.000MHz Ω 60 AT-Cut Fundamental ~ 60.000MHz Outline Drawing & Recommended Landed Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad Crystal SXT214 Series 2.0mm x 1.6mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K Moisture Resistance MIL-STD-883, Method 1004 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Solderability MIL-STD-883, Method 2003 Reflow Profile & Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 3,000pcs / Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
物料型号:SXT 21 4 18 A A 48 - 25.000M
器件简介:SXT214系列是一款超小型封装的AT-Cut基础晶体振荡器,适用于办公自动化、音视频、蓝牙、小型通信设备、SSD和USB等应用。
引脚分配:文档中未明确提供引脚分配图,但通常4脚晶体振荡器的引脚为两个电源引脚和两个输出引脚。
参数特性: - 频率范围:16MHz至60MHz - 频率容差:±10ppm至±50ppm,具体取决于型号 - 频率稳定性:±10ppm至±20ppm,具体取决于型号 - 工作温度范围:-40°C至+85°C,具体取决于型号 - 负载电容:8pF至32pF,具体取决于型号 - 绝缘电阻:最小500MΩ(在100VDC±15V下) - ESR:不同频率范围有不同的值,从5至120欧姆
功能详解:文档中未提供详细的功能解释,但晶体振荡器通常用于为电子设备提供稳定的时钟信号。
应用信息:适用于办公自动化、音视频、蓝牙、小型通信设备、SSD和USB等。
封装信息:2.0mm x 1.6mm的超小型封装,符合RoHS标准。
环境和机械规格:包括温度循环、微漏测试、粗漏测试、振动、耐焊接热、耐溶剂等。
回流焊接曲线和部件标记:提供了详细的回流焊接温度曲线和部件标记信息。
胶带和卷轴尺寸:提供了卷轴的尺寸和每卷的数量(3000pcs/卷)。
SXT21410DB38-25.000MT 价格&库存
很抱歉,暂时无法提供与“SXT21410DB38-25.000MT”相匹配的价格&库存,您可以联系我们找货
