7R-32.000MDAV-T
7R-32.000MDAV-T
    TXC(台晶)
    SMD-4
    无源晶振 120Ω 32MHz 8pF ±20ppm -20℃~+70℃ SMD-4
7R-32.000MDAV-T 数据手册
7R MHz Crystal Features Frequency range : 20MHz to 64MHz Compact and thin Glass sealing, ceramic SMD package External dimensions (mm) L : 2.0 x W : 1.6 x H : 0.6 RoHS compliant Contains Pb, exempted by RoHS directive Applications Notebook, Hard disk Computer peripherals OA, AV applications Home electronics Portable consumer products Electrical Characteristics Item 7R Frequency Range F0 20MHz ~ 64MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±50 ppm ±30 ppm ±20 ppm ±60 ppm -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 Drive Level DL Load Capacitance CL 6pF, 7pF, 8pF, 9pF, 10pF 12pF, 16pF, 18pF, 20pF Aging Faging ±3 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C 2pF Max. 1 ~ 100μW (10μW Typ.) at 25°C ± 3°C,first year Motional Resistance (ESR) Fundamental 20 ~ 24 24 ~ 30 30 ~ 36 36 ~ 64 Rev. 1.04 MHz MHz MHz MHz 200Ω 150Ω 120Ω 80Ω Max. Max. Max. Max. Page 1 www.txccrystal.com 7R MHz Crystal Dimensions Ordering Information 7R - 16.000M A H E Frequency in Hz - T Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E ± 30 ppm ± 20 ppm ± 10 ppm Frequency Stability (over Temp.) A D E T G H I K Rev. 1.04 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 50 ppm ± 30 ppm ± 20 ppm ± 60 ppm B Y V C Q E I J K 6 pF 7 pF 8 pF 9 pF 10 pF 12 pF 16 pF 18 pF 20 pF ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.txccrystal.com 7R MHz Crystal Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 5°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.04 60 sec Page 3 Time (sec) www.txccrystal.com
7R-32.000MDAV-T
物料型号:7R MHz Crystal
器件简介:该晶体振荡器适用于多种应用,包括笔记本电脑、硬盘、家用电器、便携式消费电子产品、计算机外设、办公自动化和音视频应用。
引脚分配:文档提供了晶体振荡器的顶视图、侧视图和底视图,以及晶体连接的示意图,但未提供具体的引脚分配信息。
参数特性:晶体振荡器的频率范围为20MHz至64MHz,具有不同的频率容差选项,如±30ppm、±20ppm、±10ppm。还提供了在不同温度范围内的频率稳定性数据,以及工作温度范围、电容、驱动电平和负载电容等参数。
功能详解:文档详细描述了晶体振荡器的电气特性,包括频率范围、频率容差、频率稳定性、工作温度范围、电容、驱动电平和老化特性。
应用信息:晶体振荡器适用于多种电子设备和系统,包括但不限于上述提到的应用领域。
封装信息:晶体振荡器有玻璃密封、陶瓷SMD封装,外部尺寸为长2.0mm、宽1.6mm、高0.6mm。
7R-32.000MDAV-T 价格&库存
很抱歉,暂时无法提供与“7R-32.000MDAV-T”相匹配的价格&库存,您可以联系我们找货
