S7A3310-156.250-L-X-CT
    AKER(安碁科技)
    SMD-6
    有源晶振 2.5V SMD-6 156.25MHz
S7A3310-156.250-L-X-CT 数据手册
RoHS Compliant Pb - Lead Free Ltr Revisions Appr Date Electrical Specifications: Frequency Range Frequency Stability over Temperature Aging per Year Standard Extended Operating Temperature Range Storage Temperature Range Supply Voltage Input Current Output Voltage Differential Output Voltage (Vod) Offset Voltage (Vos) Output Symmetry Output Type Output Load (Between Q ansd QN) Rise and Fall Time Input Enable Voltage Input Disable Voltage Phase Jitter (12 KHz to 20 MHz) 13.500 to 99.999MHz 100.000 to 160.000MHz 161.000 to 800.000MHz Logic High (Voh) Logic Low (Vol) 13.500 to 99.999MHz 100.000 to 160.000MHz 161.000 to 800.000MHz 13.500 to 160.000MHz 161.000 to 800.000MHz 13.500 to 800.000 ±100 ±50 ±25 ±3 -10 to +70 -40 to +85 -55 to +125 1.8 ± 5% 2.5 ± 5% 3.3 ± 5% 50 50 50 50 50 50 50 50 1.6 1.6 1.6 0.9 0.9 0.9 247 to 454 1.125 to 1.375 45 to 55 LVDS - Complimentary Output 100 1 1 1 0.5 0.5 0.5 0.5 0.5 1.26 1.75 2.31 0.54 0.75 0.99 1 2 MHz PPM Max ºC Vdd mA Max Vdd Min Vdd Max mV V % - Ω ns Max Vdd Min Vdd Max ps RMS Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: MK Appr: 1/4 Page: Date: Oct 20, 2019 Clock Oscillator LVDS - Complimentary Output 5.0 x 7.0 mm Surface Mount - 6 Pad General Product Specification Part Number: S7A Series www.aker-usa.com Solder Pattern: Mechanical Outline: C1: 0.01 uF or 0.1 uF decoupling capacitor is recommended. C2: By-Pass capacitor for noise suppression. Contact Aker for suggested values. *Package Height: 1.4 mm Max for 77 to 159.900 MHz 1.8 mm Max for 160 to 625 MHz Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Pad Connection: Pin Connection 1- INH 2- NC 3- GND 4- Output - Q 5- Comp. Output - QN 6- Vdd Top View Page: 2/4 Date: Oct 20, 2019 P/N: S7A Series www.aker-usa.com A B 8.0 ¡ Ó 0.1 Ko:2.0 Ao:5.4 5¢X (max) Dimensions are millimeters. A-A SECTION Solder Reflow Characteristics: Page: 3/4 B-B SECTION AKER AKER +0.1 1.7 -0.0 AKER AKER A 5¢X(max) Pin #1 Bo:7.9 B 0.3 ¡ Ó 0.05 16.0 ¡ Ó0.3 4.0 ¡ Ó 0.1 7.5 ¡ Ó0.1 +0.1 1.5 -0.0 2.0 ¡ Ó 0.1 1.75 ¡ Ó0.1 Carrier Tape Dimensions: Date: Oct 20, 2019 P/N: www.aker-usa.com S7A Series How to build a Part Number: Series Package S 7A Parameter 5.0 x 7.0 mm - 6 Pad Supply Voltage 18 25 33 +1.8 Vdd ± 5% +2.5 Vdd ± 5% +3.3 Vdd ± 5% Temperature Stability 10 05 025 ±100 PPM ±50 PPM ±25 PPM Frequency Output Load Temperature Range Packaging 13.500 - 800.000 L See Notes X M R - MHz - LVDS - -10 to +70 ºC -40 to +85 ºC - 250pcs Reel 1000pcs Reel Part Number Example: S7A3305-155.520-L-X-R S7A: 5.0 x 7.0 mm SMD Package - 6 Pad 33: +3.3 Vdd Supply Voltage 05: ±50 PPM Temperature Stability 155.520 MHz Nominal Frequency L: LVDS Output X: -40 to + 85° C Extended Temperature Range R: Tape and Reel Packaging Notes: 1- Standard Temperature Range does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 3- Quantities less than 250pcs are shipped in tape. 4- Specification subject to change without notice. Page: 4/4 Date: Oct 20, 2019 P/N: www.aker-usa.com S7A Series
1. 物料型号:S7A系列。 2. 器件简介:文档描述了一种时钟振荡器,具有LVDS互补输出,封装为5.0 x 7.0 mm表面贴装6个焊盘。 3. 引脚分配:引脚1为INH,2为NC(无连接),3为GND,4为输出Q,5为互补输出QN,6为Vdd(电源电压)。 4. 参数特性: - 频率范围:13.500至800.000 MHz。 - 频率稳定性:±50 PPM至±100 PPM,取决于温度范围。 - 老化率:每年±3 PPM。 - 工作温度范围:标准为-10至+70°C,扩展为-40至+85°C。 - 存储温度范围:-55至+125°C。 - 电源电压:1.8V、2.5V、3.3V,±5%容差。 - 输入电流:在不同频率下最大为50 mA。 - 输出电压:高电平1.6V,低电平0.9V。 - 差分输出电压:247至454 mV。 - 偏移电压:1.125至1.375 V。 - 输出对称性:45%至55%。 - 相位抖动:在不同频率下为1至2 ps RMS。 5. 功能详解:文档提供了详细的电气规格和性能参数,包括频率稳定性、老化率、输入电流、输出电压等。 6. 应用信息:适用于需要精确时钟信号的应用,如通信设备、数据转换器等。 7. 封装信息:封装为Seam Sealed Ceramic-Metal,具有特定的机械尺寸和焊盘图案。
S7A3310-156.250-L-X-CT 价格&库存
很抱歉,暂时无法提供与“S7A3310-156.250-L-X-CT”相匹配的价格&库存,您可以联系我们找货
