Revisions
Ltr
Date
Appr
RoHS Compliant
Pb - Lead Free
Electrical Specifications:
Frequency Range
1.000 ~ 156.250
MHz
Frequency Stability
±20 ~ ±100
ppm
±3
ppm Max.
Aging per Year
Operating Temperature Range
Standard
-10 ~ +70
Extended
-40 ~ +85
-55 ~ +125
Storage Temperature Range
1.8 ± 5%
2.5 ± 5%
3.3 ± 10%
1.000 to 9.999MHz
5
6
7
7
10.000 to 19.999MHz
6
8
7
7
20.000 to 31.999MHz
6
8
12
12
32.000 to 54.000MHz
15
54.001 to 79.999MHz
25
25
80.000 to 156.250MHz
25
30
30
30
Supply Voltage
Input Current
Output Voltage
1.62 ~ 3.63
VDD
mA Max.
Logic High (Voh)
90%
VDD Min.
Logic Low (Vol)
10%
VDD Max.
Output Symmetry (Duty Cycle)
Standard
40 ~ 60 ( at 50% VDD)
Tight
45 ~ 55 ( at 50% VDD)
Output Level
CMOS
Output Load
15
Rise and Fall Time
°C
pF Max.
1.000 to 9.999MHz
7
5
5
7
10.000 to 19.999MHz
7
5
5
7
20.000 to 31.999MHz
6
5
5
6
32.000 to 54.000MHz
6
5
5
6
54.001 to 79.999MHz
7
6
5
7
7
6
5
7
ns Max.
1
Phase Jitter (12 KHz to 20 MHz)
ps Max. RMS
Tri-State
Enable-Disable Function
ms Max.
10
Start Up Time
Temperature stability is Inclusive of all conditions:
Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage change,
output load change, shock, vilbration, and 1st year aging at +25°C.
Specification Title:
No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan
All dimensions are millimeters.
CAD:
TCR
Review:
EG
Appr:
JL
Page:
1/4
Date: July 1,2020
HCMOS Output Clock Oscillator
Miniature
3.2 x 2.5 millimeter Surface Mount
General Product Specification
Part Number:
www.aker-usa.com
S3 Series
Mechanical Outline and Solder Pad Layout:
3.2 ± 0.15
Metal Lid
#3
#4
2.5 ± 0.15
Ceramic Base
AKER
#1
#2
1.2 Max.
1.2
2.2
#4
#3
1.0
0.65
1.6
#2
1.0
#1
0.9
1.4
Pin Connection
PIN No.
#1
Enable/Disable Function
PIN #1
Connection
Enable/Disable
#2
GND
#3
Output
#4
VDD
PIN #3
HIGH or OPEN
Operating
LOW
High Impedance
Package is Seam Sealed Ceramic-Metal.
Terminator Pads are Ni/Au.
Dimensions are millimeters.
Page: 2/4
Date : July 1,2020
www.aker-usa.com
P/N: S3 Series
1.5
2.0
1.75
Carrier Tape Dimensions:
4.0
B-B SECTION
AKER
AKER
AKER
AKER
AKER
AKER
AKER
AKER
A
3.4
Pin #1
A
8.0
3.5
B
B
1.0
4.0
1.4
2.7
A-A SECTION
Solder Reflow Characteristics:
Page: 3/4
Date : July 1,2020
www.aker-usa.com
P/N: S3 Series
How to build a Part Number:
Series
Package
S
3
Parameter
3.2 x 2.5 mm
Supply Voltage
33
25
18
M
+3.3 VDD ± 10%
+2.5 VDD ± 5%
+1.8 VDD ± 5%
+1.62 ~ +3.63 VDD
Temperature Stability
10
05
03
025
±100 ppm
±50 ppm
±30 ppm
±25 ppm
Duty Cycle
See Notes
T
40%~60%
45%~55%
Frequency
1.000~156.250
MHz
Temperature Range
See Notes
X
-10 ~ +70 °C
-40 ~ +85 °C
Packaging
M
R
R3
250pcs Reel
1000pcs Reel
3000pcs Reel
Part Number Example:
S33305T-50.000-X-R
S3: 3.2 x 2.5 mm SMD Package
33: +3.3±10% VDD Supply Voltage
05: ±50 ppm Temperature Stability
T: 45%~55% Tight Symmetry
50.000 MHz Nominal Frequency
X: -40 ~ + 85°C Extended Temperature Range
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description.
2- Product is shipped in Tape and Reel configuration.
3- Quantities less than 250pcs are shipped in tape only.
4- Specification subject to change without notice.
Page: 4/4
Date : July 1,2020
www.aker-usa.com
P/N: S3 Series
很抱歉,暂时无法提供与“S33305T-32.768-X-R”相匹配的价格&库存,您可以联系我们找货
