LFXTAL036401REEL
LFXTAL036401REEL
    IQD
    SMD5032_4P
    无源晶振 12MHz ±20ppm 18pF 90Ω -20℃~+70℃
LFXTAL036401REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL036401Reel Customer Part: Description Standard 5x3.2mm SMD crystal with four pads. Ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPX-104 iss:9.06 Model Issue number 9 Frequency Parameters Frequency 12.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±20.00ppm @ 25°C ±50.00ppm Operating Temperature Range -20.00 to 70.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Outline (mm) Electrical Parameters 18.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 90.00Ω max Environmental Parameters Shock: 1500g, 0.5ms, 3 times in each of 3 mutually perpendicular planes Vibration: 20g (20Hz-2000Hz), 1.52mm amplitude, 20mins in 3 mutually perpendicular planes, 4 cycles Storage Temperature Range: -55 to 125°C Manufacturing Details RoHS Terminations RoHS Reflow Temp Au 0.3um~1.0um 260degC max for 30s max Recommended Solder Pad Layout Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 2 Dec 21 18:56 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL036401REEL
- 物料型号:LFXTAL036401Reel - 器件简介:标准5x3.2mm的表面贴装晶体,带四个垫片。采用陶瓷封装和密封金属盖,密封性良好。 - 引脚分配:文档未明确说明引脚分配,但通常这类晶体会有两个引脚用于连接电路。 - 参数特性: - 频率:12.0MHz - 频率容差:25°C时±20.00ppm,-20.00到70.00°C时±50.00ppm - 负载电容(CL):18.00pF - 谐振电容(C0):最大7pF - 驱动电平:最大100µW - 等效串联电阻(ESR):最大90.00Ω - 功能详解:文档未提供详细功能描述,但石英晶体通常用于频率控制和稳定电路。 - 应用信息:适用于需要精确频率控制的电子设备。 - 封装信息: - 封装类型:CFPX-104 - 封装尺寸:5x3.2mm - 存储温度范围:-55至125°C - 制造细节:符合RoHS标准,最高260°C的回流温度,持续时间不超过30秒。 - 包装详情:卷带包装,符合EIA-481-D标准,每卷1000个。
LFXTAL036401REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL036401REEL”相匹配的价格&库存,您可以联系我们找货
