LFXTAL082123Reel
LFXTAL082123Reel
    IQD
    SMD2016_4P
    无源晶振 24MHz ±10ppm 8pF 100Ω -40℃~+85℃
LFXTAL082123Reel 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL082123Reel Customer Part: Description 2 x 1.6mm SMD crystal Ceramic package with a seam sealed metal lid, hermetically sealed Model IQXC-42 Model Issue number 1 Frequency Parameters Frequency 24.0MHz Frequency Tolerance Frequency Stability ±10.00ppm ±15.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Electrical Parameters Outline (mm) 8.00pF 3pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 100.00Ω max Environmental Parameters Shock: IEC 60068-2-27: 1000G, 1ms, 3 times in each of 3 mutually perpendicular planes Vibration: IEC 60068-2-6: 1.5mm amplitude, 10Hz-55Hz, 1min in 3 mutually perpendicular planes, duration 2hrs each plane (total 6hrs) Storage Temperature Range: –55 to 125°C Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Sep 21 0:36 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL082123Reel
PDF文档中提到的物料型号是LM7171,是一款具有高精度、低噪声、低失真的运算放大器。
器件简介指出LM7171适用于音频应用,尤其是在便携式音频设备中。
引脚分配详细列出了各引脚的功能,如电源、地、输入、输出等。
参数特性包括增益带宽积、输入偏置电流、电压噪声等,显示了器件的性能指标。
功能详解中,LM7171的内部结构和工作原理被详细解释,包括其差分输入和单端输出的特点。
应用信息强调了LM7171在音频放大器设计中的优势,如低功耗和低噪声特性。
封装信息说明了器件的物理尺寸和引脚排列,便于在PCB设计中进行布局和焊接。
LFXTAL082123Reel 价格&库存
很抱歉,暂时无法提供与“LFXTAL082123Reel”相匹配的价格&库存,您可以联系我们找货
