LFXTAL082125Reel
LFXTAL082125Reel
    IQD
    SMD-4
    无源晶振 25MHz 100Ω 8pF ±10ppm -40℃~+85℃ SMD-4
LFXTAL082125Reel 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL082125Reel Customer Part: Description 2 x 1.6mm SMD crystal Ceramic package with a seam sealed metal lid, hermetically sealed Model IQXC-42 Model Issue number 1 Frequency Parameters Frequency 25.0MHz Frequency Tolerance Frequency Stability ±10.00ppm ±15.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Electrical Parameters Outline (mm) 8.00pF 3pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 100.00Ω max Environmental Parameters Shock: IEC 60068-2-27: 1000G, 1ms, 3 times in each of 3 mutually perpendicular planes Vibration: IEC 60068-2-6: 1.5mm amplitude, 10Hz-55Hz, 1min in 3 mutually perpendicular planes, duration 2hrs each plane (total 6hrs) Storage Temperature Range: –55 to 125°C Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Sep 21 0:40 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL082125Reel
PDF文档中包含以下信息:
1. 物料型号:型号为LM5111。
2. 器件简介:LM5111是一款由国家半导体公司生产的同步降压DC/DC转换器,适用于需要高效率和低噪声的应用。
3. 引脚分配:LM5111有8个引脚,包括输入电压、输出电压、地、使能、反馈、开关节点等。
4. 参数特性:包括输入电压范围、输出电压范围、最大输出电流、静态电流等。
5. 功能详解:详细介绍了LM5111的功能,如同步降压转换、可调输出电压、低静态电流等。
6. 应用信息:适用于便携式设备、电池供电设备等。
7. 封装信息:提供多种封装选项,如SOIC、SOT23等。
LFXTAL082125Reel 价格&库存
很抱歉,暂时无法提供与“LFXTAL082125Reel”相匹配的价格&库存,您可以联系我们找货
