SXTHM218CB074-40.000MT
    SUNTSU
    HC-49S/SMD
    无源晶振 18pF 40MHz 30Ω ±25ppm HC-49S/SMD 0℃~+70℃
SXTHM218CB074-40.000MT 数据手册
Metal Can SMT 2 Pad Crystal SXTHM2 Series HC-49/US Features Applications • ±10ppm/±10ppm (Tolerance/Stability) Available • Microprocessors • RESISTANCE WELD • Modems • Computers • AT-Cut or BT-Cut • Wireless Applications • Tape and Reel Part Numbering Guide SXT HM 2 18 A A 48 4 T - 4.000M SUNTSU CRYSTAL FREQUENCY MHz HC-49/US SMT MODE OF OPERATION BLANK : Fundamental HEIGHT OF PACKAGE T : 3rd Overtone 4 : 4.5mm Max B : BT-Cut Fundamental LOAD CAPACITANCE 3 : 3.2mm Max S : Series OPERATING TEMPERATURE FREQUENCY TOLERANCE 7-30 : 7pF - 30pF RANGE** A : ±50ppm FREQUENCY STABILITY 07 : 0°C - +70°C B : ±30ppm A : ±50ppm 16 : -10°C - +60°C C : ±25ppm B : ±30ppm 17 : -10°C - +70°C D : ±20ppm C : ±25ppm 27 : -20°C - +70°C E : ±15ppm D : ±20ppm 38 : -30°C - +85°C F : ±10ppm E : ±15ppm 48 : -40°C - +85°C F : ±10ppm* 2 PAD COMPLIANT Cage Code: 4GUT4 To customize your parameters contact a Suntsu representative. * For frequency stability option F contact a Suntsu representative. ** For operating temperatures of -55-125°C a Suntsu representative. Electrical Parameters Frequency Range Units Minimum MHz 3 Typical Maximum 40 Remarks AT-Cut Fundamental Frequency Range MHz 20 50 BT-Cut Fundamental Frequency Range MHz 24 90 3rd Overtone. Frequency Tolerance at +25ºC ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Op Temp ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Aging First year @ +25ºC. ppm -3 +3 Operating Temperature °C -40 +85 Storage Temperature °C -40 +125 Load Capacitance pF 7 30 Shunt Capacitance pF Drive Level µW Insulation Resistance MΩ See part numbering guide for options. See part numbering guide for options. 7 100 500 500 @ 100VDC ± 15V. 3.000MHz ~ 3.799MHz Ω 180 AT-Cut Fundamental 3.800MHz ~ 4.499MHz Ω 150 AT-Cut Fundamental 4.500MHz ~ 5.999MHz Ω 120 AT-Cut Fundamental 6.000MHz ~ 7.999MHz Ω 100 AT-Cut Fundamental 8.000MHz ~ 9.999MHz Ω 80 AT-Cut Fundamental ESR - 10.000MHz ~ 12.999MHz Ω 60 AT-Cut Fundamental 13.000MHz ~ 19.999MHz Ω 50 AT-Cut Fundamental 20.000MHz ~ 40.000MHz Ω 30 AT-Cut Fundamental 20.000MHz ~ 50.000MHz Ω 40 BT-Cut Fundamental 24.000MHz 39.999MHz Ω 100 3rd Overtone 40.000MHz ~ 90.000MHz Ω 80 3rd Overtone ~ www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Metal Can SMT 2 Pad Crystal SXTHM2 Series HC-49/US Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Mechanical Specifications Environmental Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition C Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K Moisture Resistance MIL-STD-883, Method 1004 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Solderability MIL-STD-883, Method 2003 Reflow Profile & Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 1,000pcs / Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
物料型号:SXT HM 2 18 A A 48 4 T - 4.000M
器件简介:SUNTSU的SXTHM2系列晶体振荡器,采用金属罐表面贴装2脚封装(HC-49/US),适用于微处理器、计算机、调制解调器和无线应用。
引脚分配:文档中未明确指出具体的引脚分配,但根据HC-49/US封装的通用标准,通常两个引脚分别为电源和地。
参数特性: - 频率范围:3MHz至40MHz(AT-Cut基础模式),20MHz至50MHz(BT-Cut基础模式),24MHz至90MHz(3次泛音) - 频率容差:±10ppm(+25°C时) - 频率稳定性:根据操作温度不同,范围从±50ppm至±10ppm - 工作温度:-40°C至+85°C,具体范围根据型号编号指南选择 - 负载电容:7pF至30pF,具体值根据型号编号指南选择 - 绝缘电阻:500MΩ(在100VDC±15V下)
功能详解:文档提供了详细的频率范围、频率容差、频率稳定性、工作温度、存储温度、负载电容、并联电容、驱动电平和绝缘电阻等参数的电气特性。
应用信息:适用于微处理器、计算机、调制解调器和无线应用。
封装信息:金属罐表面贴装2脚封装(HC-49/US),最大高度为4.5mm或3.2mm,具体尺寸根据型号编号指南选择。
环境和机械规格:文档还提供了温度循环、微漏测试、粗漏测试、耐湿性、耐溶剂性、耐焊接热、振动和冲击等环境和机械规格。
回流焊接曲线和零件标记:提供了回流焊接温度曲线和零件标记信息。
SXTHM218CB074-40.000MT 价格&库存
很抱歉,暂时无法提供与“SXTHM218CB074-40.000MT”相匹配的价格&库存,您可以联系我们找货
