QTM532DH-625.000MCE-T
    QST(矽睿)
    SMD5032_8P
    有源晶振 625.000000MHz 2.5V -40℃~+85℃ LVDS
QTM532DH-625.000MCE-T 数据手册
QTM532DH MHz LVDS Oscillator Fuel The Digital World Features ● ● ● ● ● ● ● ● Applications Frequency range : 170MHz to 2100MHz SMD seam sealing ceramic package Supply voltage : 2.5V, 3.3V LVDS output Low phase noise and phase jitter Tri-state function available External dimensions (mm) L : 5.0 x W : 3.2 x H : 1.2 RoHS compliant & Pb free ● ● ● ● ● Networking, Telecommunication, Data communication, Switch, Server, Storage Fibre channel, Ethernet, SONET, SATA, SAS, PCI-Express Optical module Microprocessor, DSP, FPGA, Clock source for ADC and DAC Test and measurement Electrical Characteristics Item Frequency Range (F0) QTM532DH 170MHz ~ 2100MHz Frequency Stability (Fstab) over Operating Temperature Range (TOTR) ±50ppm, ±25ppm Operating Temperature Range (TOTR) -40°C ~ +85°C Supply Voltage (VDD) Current Consumption (IDD) 2.5V, 3.3V -40°C ~ +85°C, Note [1] VDD ± 10% 100 mA Max. Output Type LVDS Output Load 100 Ω Offset Voltage Conditions 1.25V Typ. 247mV Min. / 454mV Max. 170MHz ~ 700MHz 150mV Min. / 454mV Max. 700MHz ~ 2100MHz Differential Output Voltage Rise & Fall Time (Tr / Tf) 0.5 ns Max. Duty Cycle 45% ~ 55% Start-up Time 10 ms Max. 20% ~ 80% of output swing Enable Voltage High, Logic "1" 70% VDD Min. Enable Voltage Low, Logic "0" 30% VDD Max. Phase Jitter (F0 = 622.08MHz) 150fs Typ. / 200fs Max. 12kHz ~ 20MHz, RMS ±3 ppm Max. at 25°C±3°C, first year Aging (Faging) Storage Temperature Range (TSTR) Input to OE pin Note [2] -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, variations over temperature, supply voltage and vibration. [2] Output will be enabled if OE is Logic "1" or Open; Output will be disabled if OE is Logic "0". [3] The standard testing environment except temperature test is 25°C±5°C, 40%~70% relative humidity. Rev. 1.01 Page 1 www.qstproducts.com QTM532DH MHz LVDS Oscillator Fuel The Digital World Dimensions Pin function Pin 1 OE Pin 2 NC Pin 3 GND Pin 4 OUT Pin 5 Pin 6 OUT VDD Pin 7 NC Pin 8 NC Recommended pad layout (Unit: mm) * Pad dimension tolerance is ±0.2mm * Power supply decoupling capacitor is required. Ordering Information QTM532DH - 622.08M B E T Please contact us for available frequencies Tape & Reel Frequency Stability Supply Voltage Rev. 1.01 T Packaging Method Frequency in Hz B C - E D 3.3 V 2.5 V Page 2 ± 50 ppm ( -40°C ~ +85°C ) ± 25 ppm ( -40°C ~ +85°C ) www.qstproducts.com QTM532DH MHz LVDS Oscillator Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min., 200 sec. Max. Peak temperature : 260°C ± 10°C, 10 sec. Min., 30 sec. Max. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.01 60 sec Page 3 Time (sec) www.qstproducts.com
QTM532DH-625.000MCE-T 价格&库存
很抱歉,暂时无法提供与“QTM532DH-625.000MCE-T”相匹配的价格&库存,您可以联系我们找货
