TSVD-HCQ33S-122.880M-TR
    TRANSKO
    SMD-4
    有源晶振 3.3V 122.88MHz SMD-4
TSVD-HCQ33S-122.880M-TR 数据手册
TSVD-HCQ33S-122.880M RoHS Compliant FR4 PCB BASED SMD CMOS VCXO (14.3 x 8.7 x 5.0mm) FEATURES: • 5G BASE STATION PERSONAL RADIO BASE STATION • • ULTRA LOW NOISE AND JITTER PERFORMANCE ■ SPECIFICATION PARAMETER FREQUENCY OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE RANGE SUPPLY VOLTAGE SUPPLY CURRENT LOGIC FAMILY LOAD LEVEL LOGIC ‘1’ (VOH) LEVEL LOGIC ‘0’ (VOL) OUTPUT SYMMETRY (DUTY CYCLE) RISE AND FALL TIME (Tr/Tf) START-UP TIME FREQUENCY DEVIATION MIN. TYP. MAX. UNIT 122.880 -40 85 °C -55 3.135 105 3.435 30 °C V mA 0.1 x VDD 55 3 V V % nS 10 mS 3.3 22 HCMOS 15pF 0.9 x VDD 45 ±20 CONTROL VOLTAGE AGING @ 25°C + 3°C PHASE JITTER ppm 0 3.3 ±3.0 V ppm fS 51 ■ PACKAGE DIMENSIONS NOTE MHz @ 10% ~ 90% VDD @ APR (Inclusive of tolerance@25°C, stability over temp, voltage chance, load change and aging @ 1ST year @ 12kHz ~ 20MHz offset ■ PHASE NOISE (TYPICAL) @ 122.88MHz 8.7 TOP 14.3 MARKING 5.0 max. SIDE Dot denotes pin 1 location 5.08 1 4 1.2 2 3 5.8 BOTTOM Unit : mm Pin Configuration 1 VC 2 GND 3 Output 4 VDD ■ SOLDER PATTERN ■ REFLOW PROFILE 1.6 Soldering 260°C 2.5 Pre-heating 8.3 * 5.08 Unit : mm *0.01µF to 0.1µF bypass capacitor recommended 200°C 150°C
TSVD-HCQ33S-122.880M-TR 价格&库存
很抱歉,暂时无法提供与“TSVD-HCQ33S-122.880M-TR”相匹配的价格&库存,您可以联系我们找货
