Our Performance Your Reputation
10MHz Low Noise/Low G-Sensitivity OCXO
NA-10M-6800 series
NA-10M-6800 Series in 25.4x25.4mm DIP package
NA-10M-6800 series is a 10.000 MHz high performance (VC)OCXO with
low phase noise(LPN) and low G sensitivity(LGS). It has excellent temperature versus
frequency stability with many available options. The part is housed in a hermetically
sealed RoHS package which protects it from extreme changes in external humidity and
pressure.
FEATURES
RoHS Compliant Standard
APPLICATIONS
Low Phase Noise
Instrument Reference
Small Hermetically Sealed Package
Microwave Communication
Tight Frequency Stability
Clock Reference for Microwave Signal Source
Low Power Consumption
Test & Measurement
Fast Warm-up Time
Telecom Systems
Electrical Frequency Tuning Input
Radar Systems
Reference Voltage Output
RoHS-Compliant (lead-free)
ELECTRICAL SPECIFICATIONS
Test conditions: VDC = +12 V; VCO = +5 V; at +25 ± 3°C unless otherwise identified
1. OUTPUT (PIN = “R.F. OUTPUT”)
Parameter
Min.
Typ.
Max.
10.000000
Unit
1.1.
Frequency (Fo)
1.2.
Initial Accuracy
1.3.
Waveform
1.4.
Level
1.5.
Load
1.6.
Harmonics
-30
dBc
1.7.
Spurious
-80
dBc
Test Condition
MHz
@ +25 ±1°C
-0.1
+0.1
ppm
after turn on power 60 minutes
Vco=+5V
Sine wave
+8
dBm
50
Ω
10Hz to 1MHz from carrier
http://www.taitien.com E-Mail: sales@taitien.com.tw
Specifications subject to change without notice
Page 1of 4
Rev(5) 01/2021
2. FREQUENCY STABILITY
Parameter
2.1.
Min.
Max.
Unit
±5, ±10, ±20, ±30, ±50, ±100
ppb
-20°C ~ +70°C
-40°C ~ +85°C
°C
Ambient
Typ.
Test Condition
referred to 25°C
Refer to Table 1 : Ordering Information
Aging
Daily
2.2.
-0.5
+0.5
ppb
after 30 days
Yearly
-50
+50
ppb
10 Years
-0.3
+0.3
ppm
+1
ppb
±5% change
ppb
root Allan variance for τ=1 sec
2.3.
Voltage
2.4.
Short term
-1
2.5.
Load
-1
+1
ppb
±5% change
2.6.
Warm-up
-50
+50
ppb
in 5 minutes @ +25 ±1°C
2.7.
G-Sensitivity
(each axis)
1
ppb/g
0.002
Option A
2.8.
Phase Noise (Max.)
Option B
Option C
referred to 1 hour
Option, Refer to Table 1 : Ordering Information
Option D
-105
-110
-115
-118
dBc/Hz
@ 1Hz
-135
-140
-142
-146
dBc/Hz
@ 10Hz
-155
-155
-155
-160
dBc/Hz
@ 100Hz
-165
-165
-165
-166
dBc/Hz
@ 1KHz
-170
-170
-170
-169
dBc/Hz
@ 10KHz
-170
-170
-170
-170
dBc/Hz
@ 100KHz
-170
-170
-170
-170
dBc/Hz
@ 1MHz
3. ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
Min.
3.1.
Tuning Range
±0.4*
3.2.
Control Voltage
0.5
3.3.
Slope
3.4.
Center Voltage
3.5.
Linearity
Typ.
Max.
Unit
ppm
+9.5
Test Condition
Referenced to frequency at nominal Center Voltage
V
Positive
+5.0
-10
V
+10
* Sufficient to adjust the oscillator to nominal frequency for 10 years. Some unit will have ±0.7ppm tuning range.
4. INPUT POWER (PIN = “+VDC”)
4.1.
Parameter
Min.
Typ.
Max.
Unit
Voltage
+11.4
+12
+12.6
V
Test Condition
Current
2.0
Steady State
4.2.
During Warm-Up
W
@ +25°C, operating -20°C ~ +70°C
2.3
@ +25°C, operating -40°C ~ +85°C
400
500
mA
Refer to Table 1 :
5. REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE")
Parameter
Min.
Typ.
Max.
Units
5.1.
Voltage
+9.25
+9.5
+9.75
V
5.2.
Source Resistance
5.3.
Load Impedance
100
10
Test Condition
Ohm
Kohm
Page 2of 4
Rev(5) 01/2021
6. ENVIRONMENTAL
Parameter
Reference Std.
6.1.
Operable Temperature
6.2.
Storage Temperature
Test Condition
Note 1
-45°C to +90°C
-50°C to +95°C
6.3.
Humidity
MIL-STD-202, Method 103
Test Condition A
6.4.
Vibration (non-operating)
MIL-STD-202, Method 201
0.06” Total p-p, 10 to 55 Hz
6.5.
Shock (non-operating)
MIL-STD-202, Method 213,
Test Condition J
30g, 11ms, half-sine
95% RH @ +40°C,non-condensing,240 hours
Note 1 : Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the
temperature range in 2.1.
Table 1 : ORDERING INFORMATION
Temp. (°C)
Ambient
Phase Noise Option
A
B
C
D
g-Sensitivity
Option
NA-10M-6810
NA-10M-6815
NA-10M-6820
NA-10M-6825
NA-10M-6830
NA-10M-6835
NA-10M-6840
NA-10M-6845
NA-10M-6860
NA-10M-6865
NA-10M-6870
NA-10M-6875
NA-10M-6880
NA-10M-6885
NA-10M-6890
NA-10M-6895
NA-10M-6811
NA-10M-6816
NA-10M-6821
NA-10M-6826
NA-10M-6831
NA-10M-6836
NA-10M-6841
NA-10M-6846
NA-10M-6861
NA-10M-6866
NA-10M-6871
NA-10M-6876
NA-10M-6881
NA-10M-6886
NA-10M-6891
NA-10M-6896
NA-10M-6812
NA-10M-6817
NA-10M-6822
NA-10M-6827
NA-10M-6832
NA-10M-6837
NA-10M-6842
NA-10M-6847
NA-10M-6862
NA-10M-6867
NA-10M-6872
NA-10M-6877
NA-10M-6882
NA-10M-6887
NA-10M-6892
NA-10M-6897
NA-10M-6813
NA-10M-6823
NA-10M-6833
NA-10M-6843
Y
N
Y
N
Y
N
Y
N
Y
N
Y
N
Y
N
Y
N
Option
±30 ppb
±20 ppb
-20°C ~+70oC
±10 ppb
±5 ppb
±100 ppb
±50 ppb
-40oC~+85oC
±30 ppb
±20 ppb
Phase Noise Test Data
OUTLINE DRAWING
Page 3of 4
Rev(5) 01/2021
Page 4of 4
Rev(5) 01/2021
很抱歉,暂时无法提供与“NA-10M-6887”相匹配的价格&库存,您可以联系我们找货
