SVC53C3D48D2-122.880M
    SUNTSU
    SMD5032_6P
    有源晶振 3.3V ±20ppm 122.88MHz SMD5032_6P
SVC53C3D48D2-122.880M 数据手册
Ceramic SMT 6 Pad CMOS VCXO SVC53C Series 5.0mm x 3.5mm Features Applications • ±20ppm (Frequency Stability) Available • Digital TV • Miniature Package • DVD, STB • CMOS • PCMIA, XDSL • Fundamental or PLL (Phase Lock Loop) Available • Broadband Access • Tape and Reel • Base Stations Part Numbering Guide SVC 53 C 3 A 48 A 2 - 27.000M SUNTSU VCXO 5.0mm x 3.5mm CMOS SUPPLY VOLTAGE 2 : 2.5V±5% 3 : 3.3V±5% 5 : 5.0V±5% FREQUENCY STABILITY A : ±50ppm B : ±30ppm C : ±25ppm Cage Code: 4GUT4 D : ±20ppm To customize your parameters contact a Suntsu representative. *E : ±15ppm * For frequency stability option E contact a Suntsu representative. COMPLIANT Electrical Parameters Units Minimum Frequency Range MHz 1 200 Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change and First Year Aging at 25°C.) ppm -20 +20 See part numbering guide for options. Operating Temperature °C -40 +85 See part numbering guide for options. Storage Temperature °C -55 +125 Supply Voltage (VDD) 2.5V Option V 2.375 2.5 2.625 Only available with AT-Cut Fundamental. Supply Voltage (VDD) 3.3V Option V 3.135 3.3 3.465 Available with AT-Cut Fundamental and PLL. V 4.750 5.0 5.250 Only available with AT-Cut Fundamental. Supply Voltage (VDD) 5.0V Option Typical OPERATING TEMPERATURE RANGE 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C Maximum FREQUENCY MHz TRI-STATE (ENABLE/DISABLE) Blank: No Connection PULLABILITY 2 : Pin 2 A : ±150ppm 5: Pin 5 B : ±100ppm C : ±80ppm D : ±50ppm Current (IDD) 2.5V Option mA 25 Current (IDD) 3.3V Option mA 25 Current (IDD) 5.0V Option mA V 0.2 2.3 Current Voltage (VC) 3.3V Option V 0.3 3.0 Pullability V 0.5 ppm ±50 Linearity % Output Load (CMOS) pF Output Logic HIGH Level (VOH) V 25mA max (AT-Cut Fund) & 50mA max (PLL). 30 Current Voltage (VC) 2.5V Option Current Voltage (Vc) 5.0V Option Remarks 4.5 ±100 ±150 See part numbering guide for options. 10 15 0.9*VDD Output Logic LOW Level (VOL) V Rise (TR) And Fall (TF) Time ns Symmetry (Duty Cycle) % 45 Tri-State Input Voltage Enable V 0.7*VDD Tri-State Input Voltage Disable V 0.3*VDD Start-Up Time ms 10 Phase Jitter (12KHz ~ 20MHz) ps 1 AT-CUT Fundamental Phase Jitter (12KHz ~ 20MHz) ps 5 PLL (Phase Lock Loop) www.suntsu.com Specifications are subject to change without notice. 0.1*VDD 5 50 55 Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad CMOS VCXO SVC53C Series 5.0mm x 3.5mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (CMOS) Waveform (CMOS) Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 27.000MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 74.1758MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad CMOS VCXO SVC53C Series 5.0mm x 3.5mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 27.000MHz Frequency - 74.1758MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 1,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad CMOS VCXO SVC53C Series 5.0mm x 3.5mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
物料型号:SUNTSU SVC53C系列
器件简介:这是一款陶瓷表面贴装(SMT)6个焊盘的CMOS VCXO,具有±20ppm的频率稳定性,提供微型封装,CMOS兼容,可选用基本模式或相位锁定环(PLL)模式。
引脚分配: - 1:电压控制 - 2:三态或无连接(NC) - 3:地(GND) - 4:输出 - 5:三态或无连接(NC) - 6:电源电压(Vcc)
参数特性: - 频率范围:至200MHz - 频率稳定性:±50ppm至±20ppm,具体取决于选项 - 工作温度范围:-40°C至+85°C,具体取决于选项 - 存储温度:-55°C至+125°C - 供电电压选项:2.5V、3.3V、5.0V - 工作电流:取决于供电电压,最大25mA或30mA - 拉出能力:±50ppm至±150ppm
功能详解: - 提供基本模式和PLL模式 - 支持三态功能,允许输出禁用 - 符合RoHS标准 - 提供不同温度范围的频率稳定性选项
应用信息:适用于数字电视、DVD、机顶盒(STB)、PCMCIA、xDSL、宽带接入和基站等。
封装信息:5.0mm x 3.5mm的小型封装,适合紧凑型设计。
环境和机械规格:符合MIL-STD-883和J-STD-020标准,包括温度循环、泄漏测试、振动、湿度抵抗等。
测试电路和典型相位噪声性能:文档提供了测试电路图和在27MHz与74.1758MHz频率下的典型相位噪声性能图表。
典型抖动性能:在27MHz和74.1758MHz频率下测量的典型抖动性能图表。
回流焊曲线:提供了推荐的回流焊温度曲线。
标记和卷带尺寸:提供了产品标记规范和卷带尺寸信息。
联系方式:Suntsu Electronics, Inc. 提供了联系信息,包括电话、传真和网站。
SVC53C3D48D2-122.880M 价格&库存
很抱歉,暂时无法提供与“SVC53C3D48D2-122.880M”相匹配的价格&库存,您可以联系我们找货
