SXO21C3C171-24.000M
SXO21C3C171-24.000M
    SUNTSU
    SMD2016_4P
    有源晶振 24.000000MHz -25~+25ppm 3.3V -10℃~+70℃ CMOS
SXO21C3C171-24.000M 数据手册
Ceramic SMT 4 Pad CMOS Oscillator SXO21C Series 2.0mm x 1.6mm Features Applications • ±20ppm (Frequency Stability) Available • Mobile Communication • Ceramic Package • Portable Electronics • CMOS • PDA • Tape and Reel • Part Numbering Guide SXO 21 C 3 A 48 1 - 24.000M FREQUENCY MHz TRI-STATE (ENABLE/DISABLE) BLANK : No Connection 1: Pin 1 SUNTSU OSC 2.0mm x 1.6mm CMOS SUPPLY VOLTAGE 1 : 1.8V±5% 2 : 2.5V±5% 3 : 3.3V±5% CO M P L I A N T FREQUENCY STABILITY A : ±50ppm B : ±30ppm C : ±25ppm *D : ±20ppm Cage Code : 4GUT4 To customize your parameters, contact a Suntsu representative. * For Frequency stability option D, contact a Suntsu representative. Electrical Parameters OPERATING TEMPERATURE RANGE 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C Units Minimum Typical Maximum Frequency Range KHz 22.000 32.768 87.000 Frequency Range MHz 1 60 Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change, and First Year Aging at 25°C.) ppm -20 +20 See part numbering guide for options Operating Temperature °C -40 +85 See part numbering guide for options Storage Temperature °C -55 +125 Supply Voltage (VDD) - 1.8V option V 1.710 1.8 1.890 Supply Voltage (VDD) - 2.5V option V 2.375 2.5 2.625 V 3.135 3.3 3.465 Supply Voltage (VDD) - 3.3V option Remarks Current (IDD) - 1.8V option mA 10 240µA max. from 22.000kHz to 87.000kHz Current (IDD) - 2.5V option mA 10 240µA max. from 22.000kHz to 87.000kHz Current (IDD) - 3.3V option mA 15 240µA max. from 22.000kHz to 87.000kHz Standby Current µA 10 From 22.000kHz to 87.000kHz Output Load (CMOS) pF 15 Output Logic Levels High (VOH) V Output Logic Levels Low (VOL) V 0.1*VDD Rise (TR) and Fall (TF) Time ns 10 Symmetry (Duty Cycle) % 45 Tri-State Input Voltage - Enable V 0.7*VDD Tri-State Input Voltage - Disable V 0.3*VDD Start-Up Time ms 10 Phase Jitter (12kHz ~ 20MHz) ps 1 www.suntsu.com Specifications are subject to change without notice. 0.9*VDD VDD -0.4 min. from 22.000kHz to 87.000kHz 50 0.4 max. from 22.000kHz to 87.000kHz 200ns max. from 22.000kHz to 87.000kHz 55 No Connection 5ms max. from 22.000kHz to 87.000kHz N/A from 22.000kHz to 87.000kHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO21C Series 2.0mm x 1.6mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (CMOS) Waveform (CMOS) Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 24.000MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 48.000MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO21C Series 2.0mm x 1.6mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 24.000MHz Frequency - 48.000MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 3,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO21C Series 2.0mm x 1.6mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
SXO21C3C171-24.000M
物料型号:SXO21C系列
器件简介:这是一款小型化的陶瓷表面贴装CMOS振荡器,具有±20ppm的频率稳定性,适用于移动通信、便携式电子设备和PDA等应用。
引脚分配: - 1:可能是三态控制或无连接(NC) - 2:地(GND) - 3:输出(OUTPUT) - 4:电源(VDD)
参数特性: - 频率范围:22.000kHz至87.000kHz,最高可达60MHz - 频率稳定性:包括初始容差、工作温度范围内的稳定性、输出负载变化、供电电压变化和第一年老化,具体数值取决于所选的稳定性选项 - 工作温度范围:-40°C至+85°C,具体取决于所选的温度范围选项 - 供电电压范围:1.8V、2.5V、3.3V,具体取决于所选的电压选项 - 工作电流:在22.000kHz至87.000kHz频率下,最大240μA - 输出负载:15pF - 输出逻辑电平:高(VoH)为0.9VDD,低(VoL)为0.1VDD - 启动时间:最大10ms - 相位抖动:在12kHz至20MHz频率下,最大1ps
功能详解:振荡器提供稳定的时钟信号,具有三态控制功能,可以在需要时禁用输出。
应用信息:适用于移动通信、便携式电子设备、PDA等。
封装信息:2.0mm x 1.6mm的小型陶瓷封装,适用于SMT工艺。
SXO21C3C171-24.000M 价格&库存
很抱歉,暂时无法提供与“SXO21C3C171-24.000M”相匹配的价格&库存,您可以联系我们找货
