C3E-28.63636-10-1010-R3 数据手册
Ltr
RoHS Compliant
Pb - Lead Free
Date
Revisions
Appr
Electrical Specifications:
Frequency Range
Fundamental
Third Overtone
Standard
Mode of Oscillation
Frequency Tolerance at 25°C
Optional
Standard
Frequency Stability over
Temperature Range
Optional
Standard
Extended
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
8.000 to 150.000
8.000 to 64.000
60.000 to 150.000
±30
±25
±20
±15
±10
±50
±30
±25
±20
±15
±10*
-10 to +70
-40 to +85
-55 to +125
±3
7 to 32 and Series Resonance
3.0
See ESR Table
100
500 at at 100 Vdc ± 15 Vdc
MHz
MHz
PPM Max
(Note 1)
PPM Max
(Note 1)
ºC
PPM Max/Year
pF
Ohm
uW Max
M Ohm
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
ESR Ohm Max
Mode of Operation
8.000 to 9.999
500
Fundamental
54.000 to 99.999
150
3rd Overtone
10.000 to 11.999
150
Fundamental
100.000 to 124.999
100
3rd Overtone
12.000 to 15.999
80
Fundamental
125.000 to 150.000
80
3rd Overtone
16.000 to 19.999
60
Fundamental
20.000 to 24.999
50
Fundamental
25.000 to 53.999
40
Fundamental
54.000 to 64.000
30
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: Dec. 5, 2018
Microprocessor Crystal Unit
Low Profile
3.2 x 2.5 millimeter Surface Mount
General Product Specification
Part Number:
C3E Series
www.aker-usa.com
Mechanical Outline:
3.2 ± 0.15
Metal Lid
#3
#4
2.5 ± 0.15
Ceramic Base
AKER
#2
#1
0.75 Max.
2.2
1.2
#2
#4
#3
1.2
0.8
1.7
0.7
#1
0.9
#2:GND #4:GND
1.4
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: Dec. 5, 2018
P/N:
www.aker-usa.com
C3E Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: Dec. 5, 2018
P/N:
www.aker-usa.com
C3E Series
How to build a Part Number:
Series
Package
C
3E
Frequency
8.000 to 150.000
Load Capacitance
Standard
Frequency Tolerance
(Note 1)
Option
Standard
Frequency Stability
(Note 1)
Option
7
10
12
16
18
S
30
25
10
50
30
25
10
Mode of Oscillation
See Notes
3
Standard
Temperature Range
Extended
See Notes
X
Packaging
M
R
R3
Parameter
3.2 x 2.5 mm
MHz
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
±30 PPM
±25 PPM
±20 PPM
± 15 PPM
±10 PPM
±50 PPM
±30 PPM
±25 PPM
±20 PPM
±15 PPM
±10 PPM*
Fundamental
Third Overtone
-10 to +70 ºC
-40 to +85 ºC
250pcs Reel
1000pcs Reel
3000pcs Reel
Part Number Example:
C3E-24.000-18-3050-X-R
C3E- 2.5 x 3.2 mm SMD Seam Seal Crystal Unit
24.000 MHz Nominal Frequency
18 pF Load Capacitance
3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability
Fundamental Mode
X: -40 to +85° C Temperature Range
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Frequency Tolerance and Stability options are limited due to physical size.
* ±10 PPM Temperature Stability is only available from -20 to +85° C.
2- Standard Temperature Range does not need to be included in part number description.
3 - Fundamental mode does not need to be included in part number description
4- Quantities less than 250pcs are shipped in tape only.
5- Specification subject to change without notice.
Page:
4/4
Date: Dec. 5, 2018
P/N:
www.aker-usa.com
C3E Series
C3E-28.63636-10-1010-R3 价格&库存
很抱歉,暂时无法提供与“C3E-28.63636-10-1010-R3”相匹配的价格&库存,您可以联系我们找货
