F5X-32768-070-D90-R-N
    RIVER(大河)
    SMD-4
    无源晶振 7pF 90KΩ ±20ppm -40℃~+85℃ SMD-4 32.768KHz
F5X-32768-070-D90-R-N 数据手册
NEW PRODUCT SMD Tuning Fork Crystal Unit TFX-05X 1.2 x 1.0 mm / 32.768 kHz FEATURES • The world’s smallest 1210size tuning fork crystal unit (32.768 kHz) • Ultra-thin (0.35 mm) / ultra-light (0.8 mg) “Crystal Package” made of quartz crystal: → 43% lighter weight than a ceramic package of the same size → Better weather-ability / excellent shock resistance → "Metal Diffusion Sealing (MDS)": Robust sealing method using metal diffusion (patent pending) (1.2 × 1.0 × 0.35 mm) • Wide operating temperature range of -40 to +105°C available • Specifications in conformity with AEC-Q200 available on request APPLICATIONS • Small wireless-modules, Wearable devices, Hearable devices, and others • Smartphones, Medical and Healthcare devices, Automotive electronics, and others STANDARD SPECIFICATIONS Item Nominal frequency 32.768 kHz Equivalent series resistance (E.S.R.) @25°C (See below for more options) 90 kΩ Max. - Motional capacitance 7.0 fF Typ. - Shunt capacitance 1.5 pF Typ. - Storage temperature -55 to +125°C - Operating temperature -40 to +85°C -40 to +105°C Temperature coefficient -0.03±0.01 ppm/°C2 - 25±5°C - Turnover temperature Load capacitance (Unit: mm) - ±20 ppm Frequency tolerance OUTLINE DIMENSIONS Conditions (Remarks) Specifications (See below for more options) 5.0, 7.0, 9.0, 12.5 pF Internal Connection #4 #3 (Other values available) Drive level 0.5 µW Max. - Tape and reel 5000 pcs/reel Reel diameter : ⌀180 mm #2 #1 Pin Connection #1 Crystal #2 Ground #3 Crystal #4 No Connection • Pin #2 is connected to the shield (*1) RECOMMENDED LAND PATTERN GENERAL NOTES 0.52 • Certain combinations of standard options may be classified as high-spec models. 0.3 (Unit: mm) 0.52 • The information in this document is subject to change without notice. • In case that the product is used in special installation environment, such as in resin mold, please consult us in advance. 0.67 0.47 0.2 0.47 • Please consult us for specifications that do not match the standard specifications. 0.82 ORDERING NUMBER GUIDE F5X 32768 090 D 90 R W ## Type TFX-05X RIVER use only (as needed) Nominal Frequency Tape and Reel 32.768 kHz W 5000 pcs/reel N Other *1 Load Capacitance Operating Temperature Frequency Tolerance 050 5.0 pF 070 7.0 pF D ±20 ppm 090 9.0 pF E ±30 ppm 125 12.5 pF F ±50 ppm 90 NNN Other *1 N Other *1 NN P -20 to +70°C R -40 to +85°C 90 kΩ Max. S -40 to +105°C Other *1 N Other *1 Equivalent Series Resistance (E.S.R.) *1. Please consult us for your requirements. RIVER ELETEC CORPORATION E-mail: river_sales@river-ele.co.jp Sales Contacts: River Electronics (Singapore) Pte.Ltd. TEL:+65-6258-7874 FAX:+65-6258-7366 Taiwan River Co.,Ltd. TEL:+886-2-8988-2811 FAX:+886-2-2983-4785 Xi'an River Electronics Corporation (China) TEL:+86-755-86528590 FAX:+86-755-86528590 http://www.river-ele.co.jp 2-1-11 Fujimigaoka, Nirasaki, Yamanashi, 407-8502, Japan Nov. 20 .2020
F5X-32768-070-D90-R-N 价格&库存
很抱歉,暂时无法提供与“F5X-32768-070-D90-R-N”相匹配的价格&库存,您可以联系我们找货
