S3A3305-50.000-L-X-M
    AKER(安碁科技)
    SMD-6
    有源晶振 50MHz 3.3V SMD-6
S3A3305-50.000-L-X-M 数据手册
RoHS Compliant Pb - Lead Free Ltr Date Revisions Electrical Specifications: Frequency Range 13.500 - 156.250 ±100 ±50 ±25 ±3 -10 to +70 -40 to +85 -55 to +125 Frequency Stability over Temperature Aging per Year Standard Extended Operating Temperature Range Storage Temperature Range Supply Voltage Input Current Output Voltage Differential Output Voltage (Vod) Offset Voltage (Vos) Output Symmetry Output Type Output Load (Between Q ansd QN) 13.500 - 156.250 Mhz Logic High (Voh) Logic Low (Vol) 13.500 - 99.999Mhz 100.000 - 156.250Mhz Rise and Fall Time Enable-Disable Function Enable High Input Voltage Enable Low Input Voltage Phase Jitter (12 KHz to 20 MHz) MHz PPM Max ºC 2.5 ± 5% 3.3 ± 5% 50 50 1.6 1.6 0.9 0.9 247 (Min) 330 (Typ) 454 (Max) 1.125 (Min) 1.250 (Typ) 1.375 (Max) 45 to 55 LVDS - Complimentary Output 100 1 0.5 1 Ω 1 0.5 ns Max Q Pin 4 - QN Pin 5 Operating High Impedance 2.31 0.99 Vdd Min Vdd Max ps RMS Tri-State INH - Pin 1 High - Pin 1 Low - Pin 1 1.75 0.75 Vdd mA Max Vdd Min Vdd Max mV V % - Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: June 29, 2016 Clock Oscillator LVDS - Complimentary Output 3.2 x 2.5 millimeter Surface Mount - 6 Pad General Product Specification Part Number: S3A Series www.aker-usa.com Appr Mechanical Outline: Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. PCB Solder Pad Layout: Pad Connection: Top View Page: 2/4 Date: June 29, 2016 P/N: Pin Connection 1- INH 2- NC 3- GND 4- Output - Q 5- Comp. Output - QN 6- Vdd S3A Series www.aker-usa.com Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: June 29, 2016 P/N: www.aker-usa.com S3A Series How to build a Part Number: Series Package S 3A Parameter 3.2 x 2.5 mm - 6 Pad Supply Voltage 25 33 +2.5 Vdd ± 5% +3.3 Vdd ± 5% Temperature Stability 10 05 025 ±100 PPM ±50 PPM ±25 PPM Frequency Output Load Temperature Range Packaging 13.500 - 156.250 L See Notes X R - MHz - LVDS 0 to +70 ºC -40 to +85 ºC Tape and Reel Part Number Example: S3A3310-155.520-L-X-R S3A: 3.2 x 2.5 mm SMD Package - 6 Pad 33: +3.3 Vdd Supply Voltage 10: ±100 PPM Temperature Stability 155.520 MHz Nominal Frequency L: LVDS - Complimentary Output X: -40 to + 85° C Extended Temperature Range R: Tape and Reel Notes: 1- Standard Temperature Range does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 3- Quantities less than 1000 are shipped bulk in ESD pouches. 4- Specification subject to change without notice. Page: 4/4 Date: June 29, 2016 P/N: www.aker-usa.com S3A Series
1. 物料型号:S3A系列,具体型号示例为S3A3310-155.520-L-X-R。 2. 器件简介:该振荡器是一款表面贴装的6个焊盘的3.2 x 2.5毫米封装,具有LVDS互补输出。 3. 引脚分配:1-INH(抑制),2-NC(无连接),3-GND(地),4-Output - Q(输出),5-Comp. Output - QN(互补输出),6-Vdd(电源)。 4. 参数特性: - 频率范围:13.500-156.250 MHz - 频率稳定性:±100 PPM最大 - 老化率:每年±3 PPM - 工作温度范围:标准 -10到+70°C,扩展 -40到+85°C - 存储温度范围:-55到+125°C - 供电电压输入电流:最大50 mA - 输出电压:高电平1.6V,低电平0.9V - 差分输出电压:最小247mV,典型330mV,最大454mV - 偏置电压:最小1.125V,典型1.250V,最大1.375V - 输出对称性:45%到55% - 使能-禁用功能:INH-Pin 1控制Q Pin 4和QN Pin 5 5. 功能详解:包括时钟振荡器的工作原理、频率稳定性、老化率、温度稳定性等。 6. 应用信息:适用于需要精确时钟信号的应用。 7. 封装信息:3.2 x 2.5毫米表面贴装封装,6个焊盘,陶瓷基底和金属盖。
S3A3305-50.000-L-X-M 价格&库存
很抱歉,暂时无法提供与“S3A3305-50.000-L-X-M”相匹配的价格&库存,您可以联系我们找货
