SXT53410CD17-25.000M
    SUNTSU
    SMD5032_4P
    无源晶振 25MHz ±25ppm 10pF 70Ω -10℃~+70℃
SXT53410CD17-25.000M 数据手册
Ceramic SMT 4 Pad Crystal SXT534 Series 5.0mm x 3.2mm Features Applications • ±10ppm/±10ppm (Tolerance/Stability) Available • Communication and Test Equipment • Ultra-Miniature Package • Wireless Applications • PCMCIA • AT-Cut Fundamental • High Density Applications • Tape and Reel Part Numbering Guide SXT 53 4 18 A A 48 T - 27.000M SUNTSU CRYSTAL FREQUENCY MHz MODE OF OPERATION 5.0mm x 3.2mm Blank : Fundamental T : 3rd Overtone 4 PAD OPERATING TEMPERATURE LOAD CAPACITANCE FREQUENCY STABILITY RANGE** FREQUENCY TOLERANCE 07 : 0°C - +70°C S : Series A : ±50ppm A : ±50ppm 16 : -10°C - +60°C COMPLIANT 7-30 : 7pF - 30pF B : ±30ppm B : ±30ppm 17 : -10°C - +70°C C : ±25ppm C : ±25ppm 27 : -20°C - +70°C D : ±20ppm D : ±20ppm 38 : -30°C - +85°C E : ±15ppm Cage Code: 4GUT4 E : ±15ppm 48 : -40°C - +85°C F : ±10ppm* To customize your parameters contact a Suntsu representative. F : ±10ppm * For frequency stability option F contact a Suntsu representative. ** For operating temperatures of -55-125°C a Suntsu representative. Electrical Parameters Frequency Range Units Minimum MHz 7.9921 Typical Maximum Remarks 54 AT-Cut Fundamental. Frequency Range MHz 40 125 3rd Overtone Frequency Tolerance at +25ºC ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Op Temp ppm -10 +10 See part numbering guide for options. Frequency Stability vs. Aging ppm -3 +3 First year @ +25ºC. Operating Temperature °C -40 +85 Storage Temperature °C -40 +125 Load Capacitance pF 7 30 Shunt Capacitance pF Drive Level µW Insulation Resistance MΩ See part numbering guide for options. See part numbering guide for options. 7 10 50 100 500 @ 100VDC ± 15V. 8.000MHz ~ 11.999MHz Ω 100 AT-Cut Fundamental 12.000MHz ~ 19.999MHz Ω 80 AT-Cut Fundamental ESR - 20.000MHz ~ AT-Cut Fundamental 29.999MHz Ω 70 30.000MHz ~ 54.000MHz Ω 50 AT-Cut Fundamental 40.000MHz ~~ 125.000MHz 66.000MHz Ω 80 50 3rd Overtone AT-Cut Fundamental Outline Drawing & Recommended Landed Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad Crystal SXT534 Series 5.0mm x 3.2mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K Moisture Resistance MIL-STD-883, Method 1004 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Solderability MIL-STD-883, Method 2003 Reflow Profile & Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 1,000pcs / Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
- 物料型号:SXT534系列,尺寸为5.0mm x 3.2mm。 - 器件简介:超小型封装,适用于高密度应用,如通信和测试设备、PCMCIA、无线应用等。 - 引脚分配:文档中未明确提供引脚分配图,但通常4 Pad SMT晶体振荡器有2个电源引脚和2个输出引脚。 - 参数特性: - 频率范围:7.9921MHz至54MHz(基础模式)和40MHz至125MHz(三次谐波模式)。 - 频率容差:±10ppm至±50ppm,具体取决于型号。 - 频率稳定性:操作温度和老化的影响下,容差为±10ppm至±30ppm。 - 工作温度范围:-40°C至+85°C,具体取决于型号。 - 负载电容:7pF至30pF。 - 驱动电平:10μW至100μW。 - 绝缘电阻:最小500MΩ(在100VDC 15V条件下)。 - 功能详解:文档提供了详细的电气参数表,包括频率范围、频率容差、频率稳定性、操作温度、存储温度、负载电容、并联电容、驱动电平、绝缘电阻等。 - 应用信息:适用于通信和测试设备、无线应用等。 - 封装信息:5.0mm x 3.2mm的超小型封装,符合RoHS标准,提供卷带包装。
SXT53410CD17-25.000M 价格&库存
很抱歉,暂时无法提供与“SXT53410CD17-25.000M”相匹配的价格&库存,您可以联系我们找货
