CPPT4-LT5PT
CPPT4-LT5PT
    CARDINALCOMPONENTS
    DIP-8
    可编程晶振 3.3V DIP-8
CPPT4-LT5PT 数据手册
    CARDINAL COMPONENTS    Field Programmable Crystal Oscillator  ● ● ● ● ● Series CPP  Programmed in the field with the PG‐3200 oscillator programming instrument within seconds.  Factory Programmable  Can be programmed twice  Standard Package Options  Also available in 2.7V  Instrument Part Number:    CPPC1LZ‐A5B6‐XX.XXXX TS          CPP  C  1  L  Z  A5  B6  XX.XXXX  TS  SERIES  CPP          OUTPUT  C = CMOS  T = TTL        PACKAGE STYLE  1 = Full Size  4 = Half Size  5 = 3.2x5 Ceramic  7 = 5x7 Ceramic  8 = PLASTIC SMD  VOLTAGE  Blank = 5V  L = 3.3V  R = 2.7V      ADDED FEATURE  Blank = Cut Tape  B = Bulk  T = Tube  Z = Tape and Reel    OPERATING TEMP  Blank = 0°C~+70°C  A3 = ‐55~+125°C  A5 = ‐20°C~+70°C  A7 = ‐40°C~+85°C    STABILITY  B6 = ±100PPM  BP = ±50PPM  BR = ±25PPM      FREQUENCY  0.500 ~ 133.000MHz          TRI‐STATE  TS = Tri‐State  PD = Power Down        Specifications:  Description  Frequency Range:  Min  Typ  Max  Unit  0.500    133  MHz  ‐100    +100  PPM  Programmable to any discrete frequency  Available Stability Options:  ‐50  +50  ‐25  +25  Programmable Supply Voltage:   (1‐133 MHz)  4.5  5.0  5.5  V    (1‐100 MHz)  3.0  3.3  3.6  V    (1‐66.0 MHz)  2.5  2.7  3.0  V  ‐55    +125  °C  ‐20  +70  °C  ‐40  +85  °C  Operating Temperature Range Options:  Storage Temperature:  Aging:  ‐55    +125  °C      ±5  PPM/Year  Min  Max  Unit  2.7  5.5  V      50  25    pF  pF      50  25  30  15  25    pF  pF  pF  pF  pF  Ta=°25C,Vdd=5V/3.3V  Programmable Output Level:  Operating Conditions:  CMOS/TTL  Description  VDD  Supply Voltage  CTTL      Max capacitive load on outputs for TTL levels  4.5V‐5.5V VDD, ≤ 40 MHz  4.5V‐5.5V VDD, 40 ‐ 133 MHz  CCMOS            Max capacitive load on outputs for CMOS levels  4.5V‐5.5V VDD, ≤ 66 MHz  4.5V‐5.5V VDD, 66 ‐ 133 MHz  3.0V‐3.6V VDD, ≤ 40 MHz  3.0V‐3.6V VDD, 40 ‐ 100 MHz  2.5‐3.0V VDD, ≤ 66 MHz  Cardinal Components  1801 Broadway Street  Charlottesville, VA 22902    1 of 5    Telephone: (973)785‐1333 Email: sales@cardinalxtal.com Website: www.cardinalxtal.com     CARDINAL COMPONENTS    Field Programmable Crystal Oscillator  Series CPP    Output Clock Switching Characteristics:  Description  Test Conditions  Min  Typ  Max  Unit  Duty Cycle:  ≤ 50 MHz, CL = 50 pF  45  ‐  55  %  TTL @ 1.4V  50 ‐ 66 MHz, CL = 15 pF  45  ‐  55  %  4.5‐5.5 VDD  66 ‐ 125 MHz, CL = 25 pF  40  ‐  60  %  125 ‐ 133 MHz, CL = 15 pF   40  ‐  60  %  ≤ 66 MHz, CL ≤ 25 pF  45  ‐  55  %  CMOS @ VDD/2  66 ‐ 125 MHz, CL ≤ 25 pF  40  ‐  60  %  4.5‐5.5 VDD  125 ‐ 133 MHz, CL ≤ 15 pF  60  ‐  60  %  3.0‐3.6 VDD  ≤ 40 MHz, CL ≤ 30 pF  45  ‐  55  40 ‐ 100 MHz, CL ≤ 15 pF  40  ‐  60  0.8V ‐ 2.0V, 4.5 ‐ 5.5 VDD, CL = 50 pF      1.8  ns  0.8V ‐ 2.0V, 4.5 ‐ 5.5 VDD, CL = 25 pF  1.2  ns  0.8V ‐ 2.0V, 4.5 ‐ 5.5 VDD, CL = 15 pF  0.9  ns  0.2V ‐ 0.8 * VDD, 4.5 ‐ 5.5 VDD, CL = 50 pF 3.4  ns  0.2V ‐ 0.8 * VDD, 3.0 ‐ 3.6 VDD, CL = 30 pF 4.0  ns  0.2V ‐ 0.8 * VDD, 3.0 ‐ 3.6 VDD, CL = 15 pF  2.4  ns  Duty Cycle:  Rise/Fall:  Start Up Time  Power Down Delay Time  Synchronous  Synchronous  ‐  ‐  2  ms  PWR_DOWN pin LOW to output Hi‐Z,          T/2  T+10  ns  10  15  ns        T/2  T+10  ns  10  15  ns  T = Frequency Oscillator Period  OE pin LOW to output Hi‐Z,    T = Frequency Oscillator Period  Asynchronous  Output Enable Time  RMS Period Jitter        100  ns  ≤ 33.000 MHz    40  50  ps  30  40  ps  100  250  ps  75  175  ps  > 33.000 MHz  Peak to Peak*  %  From Power On  Asynchronous  Output Disable Time  %  ≤ 33.000 MHz    > 33.000 MHz  * Jitter Tested at > 1,000,000 samples, exceeding JEDEC std JESD65  Cardinal Components  1801 Broadway Street  Charlottesville, VA 22902    2 of 5    Telephone: (973)785‐1333 Email: sales@cardinalxtal.com Website: www.cardinalxtal.com     CARDINAL COMPONENTS    Field Programmable Crystal Oscillator  Electrical Characteristics:  Description  Series CPP    Test Conditions  Min  Typ  Max  Unit  Input Characteristics (Pin 1):            VIL, Low‐Level Input Voltage  VDD = 5.0 V  ‐  ‐  0.8  V    VDD = 3.3 V  ‐  ‐  0.2 * VDD  V  VDD = 2.7 V  ‐  ‐  0.2 * VDD  V  VIH, High‐Level Input Voltage  VDD = 5.0 V  2.0  ‐  ‐  V    VDD = 3.3 V  0.7 * VDD  ‐  ‐  V  IIL, Input Low Current  VIN = 0 V  ‐  ‐  10  µA  IIH, Input High Current  VIN = VDD  ‐  ‐  5  µA            VDD = 5.0 V, IOL = 16mA   ‐  ‐  0.4  V  VDD = 3.3 V, IOL = 8mA  ‐  ‐  0.4  V  VIHTTL, High‐Level Output Voltage  VDD = 5.0 V, IOL = ‐16mA   2.4  ‐  ‐  V  VIHCMOS, High‐Level Output Voltage  VDD = 5.0 V, IOL = ‐16mA   VDD‐0.4  ‐  ‐  V  VDD = 3.3 V, IOL = ‐8mA  VDD‐0.4  ‐  ‐  V  Power Supply Current:  VDD = 5.0 V , FO ≤ 133 MHz  ‐  ‐  45  mA  (Unloaded)  VDD = 3.3 V , FO ≤ 100 MHz  ‐  ‐  25  mA  VDD = 2.7 V , FO ≤ 66.0 MHz  ‐  ‐  20  mA    ‐  10  50  µA  VDD = 5.0 V  ‐  20  ‐  µA  Output Enable Mode:  Output is Tri‐Stated          Power Down Mode:  Output is Tri‐Stated           (To Tri‐State or Power Down)   (To Enable Output or Open)  Output Characteristics:  VOL, Low‐Level Output Voltage  Standby Current:  Tri‐State Leakage Current    Cardinal Components  1801 Broadway Street  Charlottesville, VA 22902    3 of 5    Telephone: (973)785‐1333 Email: sales@cardinalxtal.com Website: www.cardinalxtal.com   CARDINAL COMPONENTS      Field Programmable Crystal Oscillator  Series CPP  *Note: Bypass VDD to GND with a 0.01μF capacitor  Style 1  Full Size 14 Pin Dip     Style 4  Half Size 8 Pin Dip      Pin #  1  7  8  14     Function  Control  GND  Output  VDD    Style 5  3.2x5 Ceramic SMD           Pin #  1  4  5  8  Function  Control  GND  Output  VDD  Style 7  5x7 Ceramic SMD    Pin #  1  2  3  4      Function  Control  GND  Output  VDD      Pin #  1  2  3  4  Function  Control  GND  Output  VDD  Recommended Solder Pad Layout   Recommended Solder Pad Layout   Cardinal Components  1801 Broadway Street  Charlottesville, VA 22902    4 of 5    Telephone: (973)785‐1333 Email: sales@cardinalxtal.com Website: www.cardinalxtal.com   CARDINAL COMPONENTS      Field Programmable Crystal Oscillator  Series CPP  *Note: Bypass VDD to GND with a 0.01μF capacitor  Style 8  Plastic SMD      Pin #  1  2  3  4  Function  Control  GND  Output  VDD      Recommended Solder Pad Layout    Cardinal Components  1801 Broadway Street  Charlottesville, VA 22902    5 of 5    Telephone: (973)785‐1333 Email: sales@cardinalxtal.com Website: www.cardinalxtal.com
CPPT4-LT5PT
物料型号:CPPC1LZ-A5B6-XX.XXXX TS
器件简介:这是一个现场可编程的晶体振荡器系列,可以在几秒钟内使用PG-3200振荡器编程工具进行编程。它还支持工厂编程,并且可以二次编程。
引脚分配:文档中提供了不同封装样式的引脚分配,例如Style 1 Full Size 14 Pin Dip、Style 4 Half Size 8 Pin Dip、Style 5 3.2x5 Ceramic SMD、Style 7 5x7 Ceramic SMD和Style 8 Plastic SMD。每个封装样式的引脚功能包括控制(Control)、地(GND)、输出(Output)和电源(Vo或Vop)。
参数特性:提供了频率范围、可编程输出电平(CMOS/TTL)、工作条件、输入特性、输出特性、功耗等详细参数。
功能详解:文档详细描述了输出时钟开关特性,包括占空比、上升/下降时间、启动时间、电源关闭延迟时间、输出禁用时间和使能时间、RMS周期抖动和峰峰抖动等。
应用信息:虽然文档没有直接提供应用信息,但从其特性可以推断,这种可编程晶体振荡器适用于需要精确时钟信号的各种电子设备。
封装信息:提供了不同封装样式的尺寸信息,包括最大尺寸和引脚间距。
CPPT4-LT5PT 价格&库存
很抱歉,暂时无法提供与“CPPT4-LT5PT”相匹配的价格&库存,您可以联系我们找货
